Stake Pocket Retractable Bed Hooks in 5.5' bed
Old Jul 25, 2011 | 04:44 PM
Augster's Avatar
Question Stake Pocket Retractable Bed Hooks in 5.5' bed
Has anyone installed retractable bed hooks in the stake pockets on a short bed?
What brand?
What thickness shimming is needed to prevent unsightly deformation of the bed rail?
What is the max load bearing capacity and how does it accomplish it, since it seems the short beds no longer have rectangular tubing welded in place in the stake pocket; just the stake opening on the bed rail.
Can't believe Ford deleted the pre-molded stake opening outline from the bed rail caps
Pix if you have 'em!
Old Jul 26, 2011 | 09:20 PM
Augster's Avatar
I gather from the lack of any replies that no one has installed stake pocket hooks in a 09+ short bed
Old Jul 29, 2011 | 09:23 AM
sharper4's Avatar
I went with the Extang after market cleats because the XLT version doesn't have access to the stake pocket for some dumb reason. They hold 500 lbs each and can move up and down the rail to your desired location. They come in a 2 pack and can be left under most tonneau covers.
Old Jul 29, 2011 | 09:41 AM
Augster's Avatar
I became interested in this item, but then read on the AutoAnything website that it will not work with spray-on type liner coatings, but it doesn't mention that on Extang's website... WTH?
Old Jul 29, 2011 | 02:05 PM
sharper4's Avatar
That surprises me given the way it grips onto the rail. I can't see why the spray-on liner would interfere.
Old Jul 29, 2011 | 02:15 PM
Augster's Avatar
I will contact Extang directly to get their answer to this...
Old Aug 1, 2011 | 09:23 AM
sharper4's Avatar
What did they say?
Old Aug 1, 2011 | 11:11 AM
Augster's Avatar
The Extang rep on the phone told me that there might be an issue only for trucks that don't have a plastic bed rail cap and have the spray-on lining go on top of the bed rail. Because of the shape of the cleat mounting (L-shaped), the rough texture of the lining may not allow the cleat to sit properly and securely.
For F150's and their plastic bed rail caps, it should work just fine.
Unfortunately for me, it will not work with my BAKFlip F1
