Floor jack location?
Old Jul 25, 2011 | 01:26 PM
Formula jg's Avatar
Is there a solid front central location that I could place a floor jack to lift up the front end at one time instead of lifting each individual front corner separately?
I looked for one on my '10 FX4 but could not see any just wondering if I overlooked it?
thx.
Old Jul 25, 2011 | 02:51 PM
F 1Fiddy's Avatar
I would try and put a stand on each frame rail in the front, so it is a stable platform and won't tip on you.
Old Jul 25, 2011 | 03:04 PM
It would take a pretty strong jack to do it, if there is suck a lift point.
Old Jul 25, 2011 | 03:34 PM
Formula jg's Avatar
F1,
Just to clarify my question is with respect to the placement of the hydralic floor jack and not the placement of the floor stands.
Bluejay,
I used my brothers 2.5 ton floor jack and lifted the rear from the axle and each front corner was raised from its individual frame rail. When I was done and lowered the truck back on the ground I noticed hydralic fluid leaking from the jack. My brother doesn't recall it leaking before he let me borrow it so you are probably right about needing a "pretty strong jack" .
Old Jul 25, 2011 | 03:40 PM
I have a 3 1/2 ton and I would not want to do the whole front at once. I do one side at a time, and use jack stands. My old 1954 has a cross member where you can lift the whole front, but it doesn't weigh close to what the 2005 weighs.
