AMP Power Steps
Old Apr 29, 2011 | 10:30 AM
Joe F's Avatar
AMP Power Steps
I read that these are the same steps that Ford uses on the Platinum F150's. Can they be installed using factory wiring (2011 Lariat) or do they have to be wired up with the wiring set up that comes with the kit?
Old Apr 29, 2011 | 11:22 AM
Timelessr1's Avatar
You need to use the kit that comes with the steps, and you still have to tap into the door triggers..that part is not plug and play.
Old Apr 29, 2011 | 11:44 AM
NCSU_05_FX4's Avatar
Installation is simple as long as you can read and follow instructions. I've got them on my truck.
- NCSU
Old Apr 29, 2011 | 07:08 PM
StickyF250's Avatar
- NCSU
Ditto!
Old Apr 29, 2011 | 11:36 PM
Desert Dawg's Avatar
The only difference I found is that the Ford supplied AMP steps are a tad bit slower to extend and retract for some reason when compared to the AMP steps I bought aftermarket. And yes, installation is pretty straightforward; even I was able to do mine myself.
Old Apr 30, 2011 | 08:13 AM
Joe F's Avatar
Thanks guys. Now all I need is for my truck to arrive so I can get to work!
Old Apr 30, 2011 | 01:20 PM
hagan525's Avatar
Where did everyone order there steps from?
Old Apr 30, 2011 | 05:39 PM
www.electricstep.com
Got the light kit for free.
- NCSU
Old Apr 30, 2011 | 09:14 PM
StickyF250's Avatar
- NCSU
Ditto!
