Big problem! airbag light on after stereo install
Old Apr 24, 2011 | 10:03 PM
codysanborn's Avatar
I just installed a kicker 12 and amp... with a line out converter and ran the remote wire to a Purple/white wire now when motor is running the light stays on... is that curtain airbag or airbag?
i do not want to lose my warrenty.
i also used a test light on a bright yellow wire to and another one but taped it all back up..
any input is extremely helpful!
2011 f150 xlt ext cab
Old Apr 24, 2011 | 10:11 PM
06yz250f's Avatar
did a cable get unplugged? happen to me on my 07.
Old Apr 24, 2011 | 10:14 PM
i dont belive so.. i could be wrong but unplugged nothing.. just added to a hot wire with my remote which uses little to no power... even unplugged remote wire and still came on....
im lost and nervous i cant get screwed by ford.. even though i did it.. dont wanna lose warrenty
Old Apr 24, 2011 | 10:26 PM
johnwill's Avatar
shouldn't that have been a blue/white?
Old Apr 24, 2011 | 10:27 PM
06yz250f's Avatar
i had never unplugged any of mine either, just somehow in the process got unplugged while messing with some wires behind the dash. i didn't get charged for anything when i had taken it into ford.
my remote wire was blue... but i ran that to a purple wire with white stripe... and now my lights on after install.
the wire i found was a 12v source i didnt think about a airbag wire...
Old Apr 24, 2011 | 11:10 PM
bumpp
Old Apr 24, 2011 | 11:18 PM
johnwill's Avatar
your're bumping a thread that is only 30 minutes stale?
Old Apr 24, 2011 | 11:29 PM
Im scratching my head in confusion of how in the world this light came on..... ive checked all connections... still on.
i am freaking out i could loose my warranty or have to pay to fix on a new truck
any one have wiring diagram for my truck?
Old Apr 24, 2011 | 11:35 PM
johnwill's Avatar
would you know how to read it?
Old Apr 25, 2011 | 12:11 AM
I work for at a power plant for a living... im pretty good.
i just cant see my airbag being on a purple wire....
unless my test light on the yellow wire triggered something ever so slightly..... who knows.
Old Apr 25, 2011 | 01:02 AM
Bighahn's Avatar
Okay I might have this confused but did you take off the dash cover to plug the remote wire into the deck? Or, did you wire it straight into the in-cab fuse box? If you took the dash cover off, check the passenger seat air bag light to see if you forgot to plug it back in. I know in my truck if it remains unplugged, the air bag light will turn on.
Old Apr 25, 2011 | 04:02 AM
ttubudd's Avatar
Do you have anything sitting on the passenger seat?? If so, move whatever is on the seat to the floor and see if it turns off.
Old Apr 25, 2011 | 09:57 AM
canadianelbow's Avatar
If you have triggered a fault code in the bag system, the truck will not just turn the light out. You have to have the light reset, and that can only be done by the dealer, or someone with a scan tool with the updates for '11. Even if you have solved the original problem, you wouldn't know it. The code has been stored in the trucks computer. All air bag system wiring has bright yellow plugs on them, and are usually a sliding type, (a PITA to unplug). NEVER tap into these wires, they are too sensitive, and the slightest change in amperage triggers the dash light.
Looks like you are going to be at the mercy of your dealer.....
Old Apr 25, 2011 | 10:07 AM
bluegreenf150's Avatar
