2011 F150 ... couple minor gripes
Old Apr 24, 2011 | 02:00 PM
TroyK's Avatar
was out looking around underneath the hood today...and holy cow is the dipstick hard to get to! my truck has the 5l and is a 4x4 so it sits fairly high. but, man did ford bury that dipstick! also, i can't believe how much dirt and water is able to get all the way up onto the valve covers! i don't remember this being an issue with my '05. i think they need to put some extra wheel well shielding up front so this doesn't happen so easily. any ford engineers listening ???
otherwise, awesome truck and i don't regret trading one bit!
Old Apr 24, 2011 | 02:24 PM
hagan525's Avatar
Mine doesn't seem to get much dirt and water up into it but now that you said something I'm going to go look.
Old Apr 24, 2011 | 02:59 PM
Captain Awesome's Avatar
ya that dip stick does suck.
Old Apr 24, 2011 | 03:00 PM
06yz250f's Avatar
how tall are yal?
Old Apr 24, 2011 | 03:31 PM
TroyK's Avatar
Originally Posted by 06yz250f
how tall are yal?
6'1"...and still have trouble getting to it!
Old Apr 25, 2011 | 10:42 AM
Bill G77's Avatar
Reaching The 2011 5.0 Dipstick To Check Oil
Most have trouble with the location of the Dipstick on the new 2011 5.0. I found that you can pull the dipstick out and check the oil no problem and put it back in no problem through the fender well on the drivers side. This can be done by gently pulling it just up and over the small U joint on the steering collum shaft and out the opening in the fender well. Then when putting it back in all you have to do is get the end of the dipstick back in the hole with your finger tips and it goes right back in easily, no problem. It's kinda of a odd way to pull the dipstick but it works just fine when your a shorter guy like me.
Take Care All
Bill G77
Old Apr 25, 2011 | 11:45 AM
Blue07STX's Avatar
I'm 6'2" and prefer to lean over the Radiator support.
Old Apr 25, 2011 | 11:51 AM
Bill G77's Avatar
Well I am 5'8" and that don't work so well for me, so the way I listed above works great being short in stature. If I was taller things would be diffrent.
Take Care,
Bill G77
Old Apr 25, 2011 | 12:30 PM
06yz250f's Avatar
imagine the possibilities
Old Apr 25, 2011 | 10:40 PM
Bill G77's Avatar
I think the possibilities would be endless.. First off my pant legs would be longer He He!!!
Take Care,
Bill G77
Old Apr 25, 2011 | 11:16 PM
Joe Rotax's Avatar
Well at least you can still get to it.
Won't be long before they'll need a special tool from Ford for $200 and have to be put on a hoist to get anywhere near the oil stick.
Old Apr 26, 2011 | 04:35 PM
Pale Screw's Avatar
Who knows. Maybe Ford will just delete the oil dipstick in future models like they have already done with the transmission dipstick.....
Old Apr 26, 2011 | 05:41 PM
tradosaurus's Avatar
Well now I found one advantage to a lowered truck.
Old Apr 26, 2011 | 06:13 PM
blackf-150's Avatar
IMO the 2011 5.0 engine compartment is the cheapest looking one out there complete with crappy foam over injectors for noise which will get filthy and the alternator on bottom of engine which will get full of mud and water and blow up some I have read r already had to replace alternators ford is just cutting too many corners for a 40K truck
Old Apr 28, 2011 | 09:31 PM
MR STEWCREW's Avatar
Hopefully my new FX4 will have the front plate underneath that blocks some of the splashing?
