Transfer case went bye bye
Old Apr 19, 2011 | 12:46 AM
Griff D's Avatar
So i dropped my 2010 off at Ford and after they looked at it they said the transfer case had burned up. the truck only has 10,000 miles on it. The truck was making a grinding type noise from underneath then it sounded like i was dragging a chain from my front tire. anyone else having issues? anyways the truck has only been in 4wd maybe 7 times, but not recently because i haven't driven the truck as much.
Old Apr 19, 2011 | 08:53 AM
EsJayEs's Avatar
As long as you only had 4WD engaged on loose surfaces (gravel, mud, ice, snow), it's probably not your fault. At least it's under warranty.
Old Apr 19, 2011 | 09:04 AM
svt450's Avatar
That is the sound mine has made on a few occasions! I took it in and they couldn't get it to repeat the sound.
Good thing there is warranty!!
Old Apr 19, 2011 | 10:20 AM
Griff D's Avatar
It was engaged mainly on soft sand roads. But yes good thing for warranty
Old Apr 19, 2011 | 10:45 AM
svt450's Avatar
Was yours making that sound all the time or only in certain conditions?
Old Apr 19, 2011 | 12:28 PM
Griff D's Avatar
started in certain conditions then gradually got worse and then became all the time.
Old Apr 19, 2011 | 01:00 PM
RES4CUE's Avatar
Gear oil probably leaked out, could have been a bad seal. Hope it get's taken care of.
Old Apr 19, 2011 | 01:58 PM
Texas F-150's Avatar
I had a similar noise not once but twice. Both times caused by cracked vacuum lines resulting in the 4wd wanting to engage. This was on an '05, but man does that kind of thing get your attention when it happens.
Old Apr 19, 2011 | 05:46 PM
Bigsmitty01's Avatar
357 miles my transfer case cracked in half and a big chunk of it fell off on the ground. Took it to the dealer and they replaced the entire unit axels and all . No noise at all, put it in 4wd high while stopped and when I took off in the snow and ice BANG and then the lovely smell of gear lube Dealer said they had never seen this before
Old Apr 20, 2011 | 08:47 AM
F_ast's Avatar
They didnt care about the lift on the truck and larger tires? Good on your dealer.
Old Apr 20, 2011 | 12:50 PM
Griff D's Avatar
no when i bought the truck i told them it was getting lifted. never had a truck that wasn't lifted that i bought from ford. Been dealing with the same guy and same dealership for years so i was good to go with that. Ford tried to give me a hard time with my 06 F150 bc it was lifted but nothing about this one thank goodness
