Ford OEM Tow Mirrors
It'll be really nice to have puddle lamps again. The wife will really appreciate it since she has to 'climb' in the truck.
Thanks for that picture. The tow mirrors do look better than the standard, for sure. They really make the truck look more rugged for doing work, than just getting grocercies.
Got my Tow Mirrors, Brake Controller, and my molded mud guards installed. He did a really good job. Everything looks excellent, $400 ($300+ $100 labor) for the Mirrors installed and $220 ($185 + $35 labor/activation) for the TBC installed. Mud gards were $120 ($75 + $45 Labor) installed.
Pics to come soon. Didn't have time to install mud guards since I'm working a lot of overtime. Hard to swallow the labor cost on the mud guards but at least it's done now.
Only if you have the time and an enclosed space away from the weather.
The Tech took 3 hours to put the mirrors on, install and program the TBC, and install the Mud guards. Actually after talking to the Tech, the mirror installation on the 2009 -2011 is easiest as the prior models needed the speakers taken out and the such.
TBC Install
Mike Up,
Where did they install TBC? In the dash or does it mount like a normal brake controller? I just picked up my 2011 Supercrew and will need to get the tow mirrors and a brake controller installed and I came across your post. On a side note I tow the exact camper except its a 2007. Thanks.
Mike Up,
No, the original F150 mirrors didn't extend at all, but they had slip on covers that added a convex mirror.
Unfortunately not. While the stock mirrors were bigger than some previous year mirrors, they don't stick out far enough or have a built in convex mirror (like the 2011).
However I have the Tow-N-See Convex Trailer Tow Mirrors, and with a smaller section of glass, on coming traffic looks like ants and it's really hard to judge passing and the such when you have any length to your trailer. The Tow-N-See Mirrors were fine with the Pop Up camper, but not the travel trailer camper.
Also, since those mirrors were suction cups and covered the regular truck mirrors, you really needed the convex glass since the flat glass version were to small to see all around you.
The **** Custom mirrors that are slip on mirrors, only have a flat glass mirror, no convex. These were the mirrors I was going to purchase until I decided on the more useful OEM trailer Tow Mirrors. These mirrors offer the convex strip on the bottom so you can see far around the sides and see even your wheels, which helps in tight campsites. The top mirror is mounted higher than the original and allows a view of the top of the camper, which is extremely helpful for low hanging limbs that'll tear up the front of a camper.
On top of that, the puddle lamps are great. They light up a large area and are much more useful than the driver's side self dimming feature of the standard truck mirrors (or at least IMO).
While I have no idea if he's correct or not, the service writer said putting a stick on convex mirror on to the originals is not recommended with the heated glass, as it could cause damage. As I said, I'm not sure about this as I was going to email Ford directly on the issue, but now that I have the OEM Tow Mirrors, no sense in that.
