New Gears for my truck?
Old Apr 5, 2011 | 02:12 PM
F150Aggie's Avatar
Question New Gears for my truck?
I have a marriage coming up and one of our plans is to buy a travel trailer. My truck currently has the 3.31 gears in it. I'm looking at upgrading to 3.55 or 3.73 gears to better haul with. I currently have a stock crew 4.6 with 17" tires, and no idea on the trailer size yet.
I know 3.55 would be OK but maybe not worth it since it's a small jump in ratio, but 3.73 may be too much since I drive in town a lot.
How much would a regear+programming cost and what ratio do you think I should go with?
Old Apr 5, 2011 | 02:24 PM
Even if you regear, you can't increase the various load limits. Buy your trailer with this in mind.
Old Apr 5, 2011 | 02:51 PM
F150Aggie's Avatar
Correct, it's not going to be anything huge, I just want be able to haul it effectively.
Old Apr 5, 2011 | 03:29 PM
06yz250f's Avatar
if you drive in town alot 3.73's will be better.
if you drive highway more, 3.55 will be better. BUT, 3.73's will give you a tad more power while towing. if it was me i'd go with a 3.73 or 4.10 gear ratio depending on trailer size and tire size you have/will have in the future.
Old Apr 5, 2011 | 05:36 PM
used2vtec's Avatar
Id at least go with a 3:73 gear. With these 6 speed trannies running a 3:73 rear end is still on the conservative side. Do you plan on adding bigger tires in the future, if so you may want to consider a 4:10.
Old Apr 5, 2011 | 05:47 PM
str8t six's Avatar
i would go with 4:10
Old Apr 6, 2011 | 07:16 AM
APT's Avatar
APT
4.10 for towing and in town. I'm not sure you need it, though. The 6-spd makes a huge difference compared to the old 4-spds. Buy the TT, try it a few trips. That's a $1500 investment for 4WD trucks.
Old Apr 6, 2011 | 07:53 AM
Joe F's Avatar
How heavy is the trailer and how often do you expect to tow it?
Old Apr 6, 2011 | 10:49 AM
F150Aggie's Avatar
Like I said in the original post, I don't have one picked out yet, and I'll tow it a few times a year.
And it's 2wd so I'll only need one axle done.
Old Apr 6, 2011 | 11:15 AM
marshal's Avatar
I'd do 4:10
Old Apr 6, 2011 | 01:25 PM
F150Aggie's Avatar
So what's the cost to do this to one axle? 2wd.
Old Apr 6, 2011 | 01:57 PM
str8t six's Avatar
Probably around 700
Old Apr 6, 2011 | 05:34 PM
F150Aggie's Avatar
excellent, thanks.
Old Apr 6, 2011 | 06:07 PM
With the steep 1st gear in the 6 speed you may not need to regear. If you do regear, the rule of thumb is go up at least 2 to make it noticeable - which for you would be 3.73.
Old Apr 6, 2011 | 06:12 PM
radar's FX4's Avatar
Originally Posted by marshal
I'd do 4:10
x3.
