TBC not working ??
Old Mar 26, 2011 | 04:36 PM
Trigger's Avatar
TBC not working ??
I installed a factory trailer brake controller in my 2010 f150. I have taken it to the dealer and had it turned on. It displays gain and power in the gauge cluster. I believe I have the relay and the fuse installed as well. But it does not work. I have no trailer brakes, they all worked with my 2004 f150 and an oddysea controller, so I know all my trailers nrakes work. Also I do not get a message saying that the trailer is connected. Can someone please shed some light on what I'm missing?
Thanks in advance,
Darrell
Old Mar 27, 2011 | 10:26 PM
Trigger's Avatar
Anyone? Do I need to take it to the dealer?
Old Mar 27, 2011 | 10:34 PM
MI02SVT's Avatar
i would guess somethins not hooked up right if its not showin that you have a trailer connected i would say take it to the dealer
Old Mar 28, 2011 | 08:19 AM
L8 APEX's Avatar
Is it as simple as a fuse or wire that feeds the trailer plug? There was a post a few months back where a guy added a controller and one dealer told him the controller was bad and the other figured out how to program and get it working.
Old Mar 28, 2011 | 02:37 PM
razorsharp1's Avatar
Trigger;
You said "you believe" the relay and fuses are in place - that is the key here - verify that they are installed first as no signals/power will get to the trailer without them.
Unless you put them in place yourself I would lay a fiver on the table that the dealer did not.......unless you specifically requested them to.....
BJ
