BakFlip help/question
Old Feb 13, 2011 | 11:33 PM
F-amous150's Avatar
Can someone please provide pics of how and where they did the drain tubes for their BakFlip cover?? I receive my BakFlip G2 this coming Wednesday and want to install it immediately but I was wondering where the drainage goes. My bed has been line-x'd including the two oval looking 'caps' at the front of the bed and didnt know if this would cause a problem or not. Also how I would go about getting through the line-x if possible to do the drain tubes.
Any advice and pictures would be greatly appreciated....the more the merrier.
Thanks in advance...
Old Feb 13, 2011 | 11:45 PM
Captain Awesome's Avatar
ya i would go threw the oval caps. i would use a drill and a bit that is a little bit smaller than the tube.then work the tube threw the hole for a tight fit.
Old Feb 14, 2011 | 03:51 AM
hallenfe's Avatar
i pulled out my plastic caps off and used a dremel tool to make the holes barely big enough to get the tubes through and then re installed them. took about 5 minutes. i would post pixs but im not at home.
Old Feb 14, 2011 | 12:23 PM
F-amous150's Avatar
See I dont think I can remove the plastic caps off since they have been line-x'd
Old Feb 14, 2011 | 03:23 PM
hallenfe's Avatar
see if you can get a dremel tool or a drill in there. you have nothing behind that panel for about 5-6 inches so you wont hit your cab.
Old Feb 14, 2011 | 03:34 PM
just grab a drill and bit and drill threw the caps it will be a piece of cake.
Old Feb 14, 2011 | 03:59 PM
nightingale's Avatar
I used a drill bit that was the same size as the tubes. Not sure what size it was though. I'll take some photos in a bit and post them.
Old Feb 14, 2011 | 06:16 PM
F-amous150's Avatar
Alright thanks for the help everyone and ya any pics would be appreciated!
