Any under seat Tool box Options...
Other than the "DU-HA"? It seems like a nice quality fit and can be bolted down, just wondered if there are any other options I haven't seen.
Thanks!
Jason
2010 Screw
Thanks!
Jason
2010 Screw
There are threads on here of how to make one out of a 1" x 8'. Shape the sides with a jig saw, screw together and use a strap to secure each side. I used some carpet from the auto section of walmart to cover it. It looks factory unless you inspect close. Cost around $25.
It was on another forum:
http://www.f150forum.com/f38/underseat-storage-66624/
The hardest part for me was finding automotive carpet. If you have black carpet, like in a FX4, the local walmart had some for 8$.
[QUOTE=06screw2wd;4484775]
Sorry - I never bothered to get clean pics after I was done with my install, but this is the jist of it.
Even Better Idea than just a box!!! I have two 10" subs and 200W amo hanging out in my garage that I took out of my Xploder when i traded it in!!!
Hmmmm.......good excuse to use the table saw at my FIL's shop!!!
[QUOTE=sharper4;4485031]
Is that a fuse and fuse holder that is only like 7 inches away from the amp? Please tell me you have a fuse on that line close to the battery
[QUOTE=Timelessr1;4486573]
I got the box from a guy that makes them online in Tenn. It came with the box, sub, amp, etc.
As for the fuse, its a funny thing. I wasn't sure about the installation and my brother had done it in the past. For whatever reason, which sounded good at the time, that same fuse appears in the rear and the front of the truck. I don't know why he thought I might need to "quick" disconnect but its a feature, not a bug.
