Get Max Tow, even if not towing?
I don't like the F150s without the tow mirrors. The mirrors make it look like more of a tougher truck. If you only knew how useful they are maybe youd stop whinning about them. I wouldn't sacrifice the other things just because of the mirrors. If I need to fold them in I just get out and do it. When did we all become such wusses that we "need" powerfold mirrors.
The tow mirrors are an option on any tow package.
Here is my suggestion though: If you want the upgraded cooling components, get the trailer tow package, but if you do not tow, do not get the max package.
I can't say as to the regular setup, but the max tow mas a stiff/harsh suspension unless you have a load on it. My payload is something like 1750...SCrew, 6.5' bed, max tow...I have 360 lbs of sand in the rear for winter traction assistance, I weight 150, plus I have another 150 to 200 pounds of "stuff" in the truck. If I take out say 400-450 of that, the rear end beats you up quite a bit. It's almost like the weight is pre-loading the springs and smoothing it out.
I had to have the max tow because if I have a truck (first one in several years), it isn't uncommon for me to hook up to trailers with 5 ton of hay on them. For a daily driver, I would not recommend the max package.
Not sure why but in Canada, the big TT mirrors are optional EVEN WITH the max tow pkg. Been that way all along.
Thats what they should do. And make the power fold TT mirrors optional for those of us that want to pay.
If you get the Max tow, you may as well go with the 3/4 ton model. It's only a couple thousand more. You'll get all the same features, better payload and Heavy Duty everything. That's with the gas engine obviously as the Diesel is a whopping $8,000 option!!!
We could play that game all day long. You're comparing apples to oranges.
Never mind, its taller, longer, rides much worse, and on and on and on and on.
"All the same features"!
But I agree, not the purpose of this thread. I have the tow package but not max tow. Has the cooling components. Trans runs cooler on the '11 than it did in my Suburban with the heavy row package.
Its been said already but until Ford starts making them just get what you want then swap out your mirrors. It will cost you a little but its been done numerous times on here. Case closed...
