Strange noise from passenger side in the rain?
First off, Let me say hello! I'm a new member here and probably will mostly be a lurker unless I have something to add to the discussion.
I just picked up a 2010 Xlt Screw, I'm loving everything about the truck except when driving in the rain. Whenever I run through a puddle I hear a tinny hollow sound like if you were to spray a hose against the side of a tin building.
The truck is really quiet otherwise, and the tinny noise seems really out of place.
Has anyone else had this problem and been able to identify what is causing this?
Thanks for any help!
Those hollow steps make all kinds of wierd noises from road debris. Wait till ya run over a big patch of anti-skid gravel.
As far as the side steps being the culprit, I wonder if installing some mudflaps would help mitigate the noise.
Thanks again for the helpful responses!
Mine did this until I added mudguards.No problems since.It was definitely the water coming off the tires onto the underside of the stepbars.
I've owned a bunch of trucks in the past but none with these hollow steps.
They could use ALOT of improvement in the design department.
I added mud guards and while it helped some with the noise, it didn't eliminate it.
It's just a band-aid on a big open wound.
They have a big open "C" channel design. (which is one of the reasons I think they make so much noise... the water/debris is forced up into the the bottom and partially trapped by the design)
I suspect whom ever mentioned they had theirs Line-x'ed were talking about the flat style.
These are the first 'tubular' style I've had. All my other trucks had the black platform factory boards.
If anyone wants to trade for a set of black Screw platforms let me know... I'll pay the shipping both ways.
