what should i do next?
Old Jan 6, 2011 | 02:36 PM
digbyz's Avatar
i'm open for anything idk what to do next, im thinking of tinting the third brake light and fog lights to match the head and tail lights i just got. im also considering getting a grille but not shure what kind. let me know what you think
Old Jan 6, 2011 | 03:27 PM
marshal's Avatar
trimming, or removal of the antenna would look good
Old Jan 6, 2011 | 03:44 PM
joshjohnson93's Avatar
IMO I would remove the running boards, then if its a 4x4 level it and add 33s", or if it's a 2wd I would lower. That's just what I would do. Nice truck btw!
Old Jan 6, 2011 | 04:06 PM
Milt IV's Avatar
good lookin truck!
id say remove the running boards, level/lower/lift, cut the antenna or replace it, painted mirror caps, exhaust, grilles, stereo upgrade, flip the tires to black wall out, remove the stickers. the sensibilities are endless. it all boils down to what you like and what you can afford.
good luck and keep us posted.
Old Jan 6, 2011 | 06:12 PM
digbyz's Avatar
milt IV, i love how clean and tasteful your truck is, i was thinking of painting the caps- but can i paint over the black plastic? and do they just pop off.
and you can cut the stock antenna? and i wanted to paint the door handle backs but idk how long the paint would last with fingernails hitting it.
Old Jan 6, 2011 | 09:54 PM
redtherocket's Avatar
I'd definatly go to a larger tire.
Not to much bigger, but something that will fill the wheel well a bit better...
I wouldn't bother leveling it...and leave the running boards. You paid for them and they save your seat from your *** dragging in and out of it.
from having to step down so low.....
I don't know what your needs are, but a good D or E rated tire alway looks better in my opinion...
Something all terrain.
In a nut shell, its all what your tastes are.
I like plain basic things. as you can see from my truck.
Old Jan 7, 2011 | 12:40 PM
Milt IV's Avatar
thanks man! im pretty sure the caps come off but it is a little more entailed than just popping them off. if you see a thread about "LED blinker mirror mod" check in there and there is steps on how to take your entire mirror apart. take them and your handles to a body shop and they will smooth the plastic and paint it. it will hold up fine if you have it done right.
you can cut your antenna down, just make sure you place the ball back on top after you cut it. it disperses a static charge or something and is there for a reason.
