new 2010 f-150 5.4l ffv engine noise?
Just bought a new 2010 f-150 supercrew with the 5.4 liter ffv engine. Trruck has 100 miles on it. Not sure if it my imagination but i think i hear a valve tap from the engine. I can hear it while sitting in cab at an idle. Almost sounds like a deisel but much quieter. I have only filled up with gas once and used sunoco regular unleaded ( 87 octane ) also ran a sync diagnogistic and everything seams fine. and yes the manual states some engine noise is normal. any thoughts on this am i loosing my mind? are my valves tapping or is this a normal noise for this engine?
any help would be greatly appreciated!!
I believe it is the fuel injectors making that noise which is normal. If the cam phaser was the problem the noise would be considerably louder and more like a knocking sound. I had the cam phaser noise on my '04. Sounded like a diesel when sitting at a drive-thru or next to a building.
It's the injectors, very common compliant, unless the phaser (VCT) is broken (unlikely I would think).
Take a look at episode 22 of the following link to help with understanding noise from the engine. They have samples of the common emitters.
http://www.flatratetech.com/index.php?categoryid=4
I have a 2009 lariat f150 5.4 ffl. Its now been like 30 degrees out here and when i start my truck and step on the gas i can hear a knocking noise coming from under the engine. This will continue until the truck is within operating temperatures and then goes away. spoke to one of the Hardline techs at Ford and they said that its Piston Slap and is a normal thing to occur during cold weather and is not a concern. He also said that this occurs on all 5.4 f150 since 2003.... Any ideas or comments guys!
