Reverse Sensor on 2010 F-150
Old Nov 26, 2010 | 12:56 PM
chavez1975's Avatar
Wondering if anybody had the same issue that I was confronted with last night. I went to move my truck and when I put my truck in reverse, the reverse sensor alarm was constantly sounding. So I put the truck in park and went to see what I was close to since it was dark out and I saw nothing in the way. I put back into reverse and alarm sounded again. I thought What the Heck. I decided to clean off the sensors since there was ice covering my truck and once I removed the ice sheet the alarm stopped sounding.
Question: is there anything I can do to stop this without shutting the sensor off?
Thanks and happy holidays.
Old Nov 26, 2010 | 01:30 PM
darkstar_420's Avatar
keep your truck clean thats about it
Old Nov 26, 2010 | 03:02 PM
Stu486's Avatar
not much you can do about ice...garage maybe? turn it off with your tailgate down too....that confused me the first time........
Old Nov 26, 2010 | 04:02 PM
Ftruck09's Avatar
Rain-x is your friend. Rub those things down with rain-x and you should not have a problem like that again. The GF's Mountaineer had the same problem with frost/ice forming on the sensors and the rain-x really does the trick.
Old Nov 27, 2010 | 12:09 AM
ncTidalWave's Avatar
not a bad idea!
Old Nov 27, 2010 | 07:07 AM
Abn150's Avatar
Hit the reset button, it will stop the beeping until you put the truck in reverse again.
Old Nov 28, 2010 | 01:06 AM
Gir's Avatar
Gir
Mine goes off when the trailer hitch is in.
Old Jan 26, 2012 | 04:11 AM
JohnnyCashAK's Avatar
I'm having the exact same problem with mine after taking it to the carwash two nights ago. While it's not the first time I've washed my truck, it is the first time I've done so when the outside temp was consistently below -3 degrees out. Think I'll give the sensors a good wiping with a clean cloth, and see if that does anything. I was worried water from the underbody spray got inside some wiring and messed things up. I've got the extended warranty so I wasn't concerned about cost, just wasn't looking forward to the 40 mile round trip to drop it off to the dealer, only to do it again when it was fixed.
Old Jan 26, 2012 | 07:19 AM
nards444's Avatar
my 08 f250 this did this, as many times as it saved me, it probably pissed me off more times. keep it clean. in the winter I would just turn it off half of the time
Old Jan 27, 2012 | 04:56 PM
goliath's Avatar
Originally Posted by ncTidalWave
not a bad idea!
Doesn't rain-x damage paint?
Old Jan 27, 2012 | 06:27 PM
High-ster's Avatar
Rain-X de-icer site:
http://rainx.com/Products/Windshield...t/De-Icer.aspx
