will 2" 4wd spacer fit a 2wd???
Old Nov 19, 2010 | 03:26 PM
texas_superman's Avatar
its my understanding that the leveling spacers fit both 4 and 2wd trucks... is that right? im looking at buying a used procomp 2" but i came off a 4wd... so should that work on my 2wd?
Old Nov 19, 2010 | 03:40 PM
Westpoint's Avatar
Yes they should. You may have to get longer U-bolts though. The 2wds don't come with any spacers from factory.
Old Nov 19, 2010 | 03:49 PM
sorry, i wasn't clear, i ment to say spacers for the front, not the block on the leaf springs...
Old Nov 19, 2010 | 04:30 PM
Westpoint's Avatar
Ya they will work on the front. My bad
Old Nov 19, 2010 | 04:32 PM
thannks alot, i though they would, but just wanted to double check. When you install the spacers, you dont have to replace the shocks do you.... its just a bolt on and go sort of mod isnt it?
Old Nov 19, 2010 | 08:30 PM
brazzeal15's Avatar
Yep. But you will need an alignment.
