Just had a Viper 5901 Install, and now have some werid thing happening.
anothe reason is i dont really have time to take it back to the installer i may one day when it starts pissing me off like if i have it locked i cannot use my pad on my door to open my truck the alarm will go off so its useless unless i have my keys. if i do start it and turn it off everything in my truck stays on... it doesnt really bother me that much
Think of the keypad as an added feature. You're replacing your regular remotes with alarm remotes. Same thing here.
I had your issue #3 when I installed a viper alarm in my Titan. It could be related to all your problems too.
The fix was the alarm module has 1 output with a negative pulse when you arm/disarm. I forgot what it's called.
I wired it to the door pin switch so when you press the remote it turns triggers the pin thinking someone opened and closed the door.
If you have Amp Research automatic steps then you would need to run a diode to it because this pulse would also activate the step since that was wired to the door pins too.
