Raptor parts on regular F-150
So I have a few ideas floating around in my head, and was wondering if someone with more wisdom than I, knew the answers to my questions.
Is it possible to put the Raptor rear end in at normal F-150 and switch out the dash switch so that the rear can be locked in 2WD, 4HI and 4LO (yes my truck is already 4x4)? I also realize that the Raptor comes with 4.10 gearing, so I would re-gear my front differential at the same time as swapping the rear axle.
Next question,
the auxiliary switches, offroad button, and hill descent:
Is it possible to get this part and hook it up to the truck? Obviously, the auxiliary switches would be no real problem. I know the offroad mode and the hill descent are achieved my modulating the ABS brake system so I'm assuming it's controlled by the truck's ECM. If we are able to install the part and get it all hooked up, could we just re-flash the ECM to have the programming from the Raptor?
I know some of these issues are more involved than others, but I don't really know about them so I figured I would just ask. I currently have the same size tires as the Raptor comes stock with and I would swap to the same gearing if the rear end swap worked, so the programming could also be the same.
Thanks in advance!!
Next question,
Thanks in advance!!
Next question,
Thanks in advance!!
Next question,
Thanks in advance!!
He stated changing the whole rear end not just the **** fyi...even though I dont know if that will work. And Im pretty sure anything can be done with some programming and ingenuity.
It would probably be a lot cheaper in the long run to just buy an aftermarket locker... you'll pay a crap ton of money for the entire Raptor rear end from Ford. Just buy an air locker for your rear end and be done with it...
But I do understand your point about the $$$, I have no idea how much they would ask for the rear end off of a Raptor.
I never thought about that. I thought it was just the fenders that were, not the actual track width or frame.
ive taken one of the fx4 switches apart and found that the lock for the rear end is just a contact switch all one would have to do i think is pull the wires out of the connector of the switch and hook it up to there own switch i broke the switch i took apart to try to make it work on a side note it would lock in 2wd but the part i cut out let the switch travel to far and the copper contacts hit some resistors and burned up the switch also if the switch is ever unplugged it defaults to locked and 4wd low
That's also unfortunate news about the wider track width and the switch. Guess that one is completely ruled out; only leaves the ARB air locker really.
My fx4 already has the e-locker so I could just mount my own switch to power it. Without the raptor programing and off road mode the tcs and rsc still limit you above 35mph in 2wd and 4x4hi which = no fun. I'm trying to make this look factory. Is this possible?
At least till the screw raptor comes out then maybe I can upgrade.
