Axle Code... I used Search!
Old Aug 12, 2010 | 12:43 AM
04x4SCREW's Avatar
2009 FX4 L6.. CAN'T find it anywhere, anyone know what it is?
Old Aug 12, 2010 | 12:57 AM
canadian_screw's Avatar
https://www.f150online.com/forums/20...xle-codes.html
You have 3.73 gears and a locker apparently. Which makes sense seeing as how you have an FX4
Old Aug 12, 2010 | 01:22 AM
04x4SCREW's Avatar
Thanks..... I guess I suck at using search..
If I go to 35's Should I go up to 4:10's?
If so can I just change the ring and pinion out and keep the stock E-locker?
Old Aug 12, 2010 | 03:25 AM
The difference between 3.73's and 4.10's is not significant enough to make it worth it. Don't sweat it - the 6 speed auto helps a lot at the low end.
Old Aug 12, 2010 | 12:55 PM
04x4SCREW's Avatar
Cool.... That saves some miney
Old Aug 12, 2010 | 01:05 PM
MGDfan's Avatar
Sir! I'm an ***! I can help!
http://lmgtfy.com/?q=f150+axle+code
MGD
Old Aug 12, 2010 | 01:06 PM
L8 APEX's Avatar
All FX4's are 3:73 from the factory.
Old Aug 12, 2010 | 01:09 PM
MGDfan's Avatar
That new? That was not the case in any of the previous gen trucks.
MGD
Old Aug 12, 2010 | 01:46 PM
kingfish51's Avatar
MGD
Definitely with the 09 up and also I believe some years in the 04-08 range.
Also the 09 was the first locker, ergo the code L6.
Old Aug 12, 2010 | 02:03 PM
blackjack8900's Avatar
MGD
Old Aug 12, 2010 | 05:12 PM
Don't feel bad, I googled it
Old Aug 12, 2010 | 06:10 PM
04x4SCREW's Avatar
MGD
Yeah Tried that!
http://www.fordf150.net/howto/decode.php NO L6 Listed
http://www.fordf150.net/forums/viewtopic.php?t=45014 Same Link
http://www.drivetrain.com/parts_cata...s_it_posi.html No L6 Listed
http://www.ford-trucks.com/article/i...de_Chart_.html Again Not Listed
http://www.ford-trucks.com/article/i...r_Decoder.html Not Listed
I Found some that stated that "6" refered to 3.73 in some Fords but the 6 in others referred to 4.56 and I was fairly certain that wasn't the case.
and If you search L6 Axle you get 248 results cause L6 is omitted, and Axle Code returns 249 results .
Sorry if I wasted anyones time.
Last edited by 04x4SCREW; Aug 12, 2010 at 06:30 PM. Reason: Not meant to be sarcastic.
Old Aug 12, 2010 | 07:45 PM
chard85's Avatar
I agree it is not a huge difference but it will make a difference if he doesn't want his acceleration to change. He will go from a 3.73 to a 3.42, but if he did the 4.10's it would bring him back to 3.73.
Old Aug 12, 2010 | 08:13 PM
04x4SCREW's Avatar
I will prolly change out, but the good thing is, it will not be required in the original setup
Old Aug 13, 2010 | 07:13 AM
kingfish51's Avatar
You definitely need to get the computer programmed to the new size. That will allow the trannie to shift at the right spots. Otherwise, you could end up with transmission problems. Unfortunately, you will have to get a programmer as the dealer cannot program for other than OE size tires.
