Leather seat care
Old Aug 5, 2010 | 10:33 AM
F-amous150's Avatar
Leather seat care
Mine are only 2 months old and already starting to see a big crease in the drivers side seat, do I need to already start putting products on the leather to avoid this...is this normal this soon? First time to have leather so bare with me. What should I do? What products work best?
Old Aug 5, 2010 | 11:25 AM
bhtyler10's Avatar
I use armor all leather care on mine. Also a major influence on how Lon you leather last is how you get in and out of your truck. Try to just sit straight to and from the seat rather than sliding in and out. Sliding out makes the outer edge weak over time.
Old Aug 5, 2010 | 11:36 AM
shotgunz's Avatar
LEATHER SEATS
(IF EQUIPPED, EXCEPT FOR THE KING RANCH SUPERCREW)
Your leather seating surfaces have a clear, protective coating over the leather.
For King Ranch SuperCrew leather seats, refer to separate section in this chapter.
• For routine cleaning, wipe the surface with a soft, damp cloth. For more thorough cleaning, wipe the surface with a mild soap and water solution. In Canada, use Motorcraft Vinyl Cleaner (CXC-93). Dry the area with a soft cloth.
• If the leather cannot be completely cleaned using a mild soap and water solution, the leather may be cleaned using a commercially available cleaning product designed for automotive interiors.
• Do not use household cleaning products, alcohol solutions, solvents or cleaners intended for rubber, vinyl and plastics, or oil/petroleum-based leather conditioners. These products may cause premature wearing of the clear, protective coating.
Note: In some instances, color or dye transfer can occur when wet clothing comes in contact with leather upholstery. If this occurs, the leather should be cleaned immediately to avoid permanent staining.
Old Aug 5, 2010 | 01:59 PM
racer114's Avatar
I use Mcguire's leather care on mine. I completely detail all my new vehicles starting at day one, including the interior. I've treated the F-150 seats three times in 6 months. They seem fine.
Old Aug 5, 2010 | 02:06 PM
shotgunz's Avatar
303 Protectant is my preferred vinyl/rubber protectant
Old Aug 5, 2010 | 02:31 PM
Toolcrib's Avatar
Lariat leather---Fx4 leather--should never be treated with anything except wiped down with a damp cloth.If you keep treating it with leather cleaners you will only compound the problem, which will keep breaking down the polymer coating which is on the seats( Which is designed not to let things penetrate)
Old Aug 5, 2010 | 05:35 PM
Nicky817Nick's Avatar
What about leather conditioner ??? Thanx..
Old Aug 5, 2010 | 05:40 PM
Did you read post #3?
Old Aug 5, 2010 | 05:43 PM
Toolcrib's Avatar
Leather conditioner would only be good for King Ranch type leather-- The hole point of the Lariat --Fx4 type leathers is so that things do not soak into the leather.Leather conditioner is just going to sit there and not soak in.
Old Aug 5, 2010 | 05:50 PM
Quackaddict's Avatar
My 2010 Lariat has perferated (sp?) leather so I think things soak in regardless, but on the edges it is not soooo, no conditioner and no leather cleaner huh interested.
It does say if it can't be cleaned with just a cloth in the 3rd post to use a commercially available cleaner
Old Aug 5, 2010 | 05:58 PM
glc,
Missed that.. Damn ADT...
Toolcrib,
Thanx for getting back so quickly.. Learn something new everyday..
Nick
Old Aug 5, 2010 | 06:17 PM
shotgunz's Avatar
2nd time's the charm...
Old Aug 5, 2010 | 06:19 PM
Spank's Avatar
Originally Posted by Nicky817Nick
glc,
Toolcrib,
Nick
That's actually "oil/petroleum based leather conditioners", which is not all leather conditioners. Many automotive leather conditioners are not oil/petroleum based.
Old Aug 6, 2010 | 07:29 AM
05BlackFX4's Avatar
after having leather seats in the stang....I would always use conditioner regardless of what Ford says.
If you dont use conditioner (with mink oil is best) your seats will crack and peel when you hit 40-50K miles if not sooner...I don't care what protectant they put on them.
Also tinting your windows will help with the aging of the leather and make it last longer.
I always use Meguiar's
Old Aug 6, 2010 | 07:45 AM
Loo's Avatar
Loo
The seats in the none Ranch versions are covered in vinyl. So leather conditioner will not work on it.
Aerospace 303.
