Autospring 2-1/2 leveling kit
Old Aug 4, 2010 | 10:51 AM
rake1's Avatar
Just wondering if anyone has had a problem with the 2-1/2 leveling kit hitting there front coil spring.
Old Aug 4, 2010 | 12:50 PM
ibcop's Avatar
I have an AS 2 1/2" kit with zero problems.
Can you clarify by what you mean when you said "hitting the coil spring"?
The kit simply bolts to the strut housing.....can you post a pic?
Old Aug 4, 2010 | 04:26 PM
L8 APEX's Avatar
The AS made for 09-up is offset to clear the spring. My 1.5" made some noise not sure what it was coming from. I do not think it was binding on the spring.
Old Aug 4, 2010 | 07:13 PM
rake1's Avatar
my upper controll arm is hitting the coil spring when I hit a bump especially if I have the wheel cut at the same time. Now I did talk to Autospring, but I didn't talk to the guy that is suppose to know all about this. So Not saying there is something wrong with the kit untill I talk to the man. Now the ford dealership where I bought the truck put it in for me. I thought I was told that the kit could only go in one way so it couldn't be installed wrong. Isn't that correct?
Ps. Just wondering if the 3/4 inch in the back is causing any trouble with the front.
