2010 Rear block size
Old Aug 5, 2010 | 06:03 PM
Quackaddict's Avatar
Originally Posted by dave m
yeah, I had it on my 07 and just swapped it over onto the '10. It actually fits with less rubbing on the new one.
Awesome, I think I am going to do the Rancho level kit in the front, 3" block in the rear with some 295/70/17 (33.3") tires. Should be good.
Again nice truck
Old Aug 5, 2010 | 08:23 PM
agdaniels's Avatar
Good deal, any issues with the traction control system and your blocks?
Old Aug 5, 2010 | 09:23 PM
Fogducker's Avatar
I was looking for some smaller blocks...like maybe 2", anyone know where to get them? I think 3" is too much for my small level on the front a AS 1.5"
Old Aug 5, 2010 | 10:01 PM
used2vtec's Avatar
+1 to this. Id really be interested in some 2 inch ones. Will the 04-08 ones work on our trucks. Its less than half an inch but it will be better than what it is now.
Old Aug 6, 2010 | 01:14 AM
dave m's Avatar
It has cut in unexpectedly a few times since putting the larger tires on. I assume this is a result of the pcm not being calibrated for the tire size and thinking something is happening that isn't. It's mostly happening while turning fairly sharp while travelling fast. My VMP SCTx3 will be here next week so hopefully that cures it. For now I just hold the traction control button for a few seconds to disable the system.
Old Aug 6, 2010 | 08:18 AM
L8 APEX's Avatar
I think Pro Comp has 2.5" blocks.
Old Aug 19, 2011 | 07:21 PM
projekt4's Avatar
i know...really old thread, but i have 1 5/8" factory blocks on my 07 and looking for 1" or the 1 1/4" factory blocks to replace mine. My truck sits just slightly too high in the back and i am trying to lower it down a touch. Anyone here have there factory 1 1/4" laying around?? let me know
Old Apr 19, 2012 | 11:03 PM
NastyFX4's Avatar
What size block does the 2011 F150 FX4 come with?
I need to add roughly 1/2" - 3/4" to the rear. Any help guys?
Old Apr 20, 2012 | 01:30 PM
NastyFX4's Avatar
I just measured mine to make sure and it was 1.25".
My truck is perfectly level right now with the 2" Autospring. However I want to raise the rear just a hair to have a slight rake. Do you think adding 2" blocks in the rear will be a good amount?
Old Apr 20, 2012 | 05:03 PM
D8Chumley's Avatar
You will only get 1/2 the amount of lift out of the size of the block. I put a 3" block on mine with a 2" LK and it has some rake back, I think it sits perfect.
Old Apr 20, 2012 | 05:35 PM
NastyFX4's Avatar
What 2" leveling kit do you have? Can you post up some pictures for me?
Old Apr 21, 2012 | 07:43 AM
D8Chumley's Avatar
This is with AS 2" LK and 3" rear blocks, 295/70-18 Nitto Terra Grapplers which is a 34"+ tall tire. That was right after I did the rear blocks over the winter, I need to take some pics with it clean.
Old Nov 15, 2012 | 10:54 AM
jjjtadpole's Avatar
Are there any issues with brake line lengths when adding the 3" block in the rear?
Old Nov 15, 2012 | 02:41 PM
scorpio333's Avatar
Shouldn't be an issue with brake lines. There may be an issue with pinion angle. I have not read about anyone having an issue. The only reason I bring it up is I recently put in a set of blocks off a Raptor. They are 2 1/2" on the front and 2 5/8 on the rear. I never encountered such a thing so I went googling, the best I can figure out is it's for pinion angle.
Here's a shot of my '12 with 2" AS and the Raptor blocks. I used 2" AS rear blocks before the Raptor blocks and it just didn't look right to me. Now I think it sits right where I want it.
Old Nov 19, 2012 | 09:36 PM
jjjtadpole's Avatar
The stance of your truck, scorpio, is perfect. Hopefully the stance on my truck will look real similar to yours.
I ordered the Rancho Quicklift Loaded for the front & 3" blocks with RS9000XL series shocks for the rear. I purchased the rear shocks are for a rear end designed for a 4" lift after talking with Rancho about the compressed and extended shock lengths. The MyRide system wil be added in a couple months.
Where did you find Raptor blocks (did they include u-bolts and nuts) and how much did you pay for them?
