2010 Lift
my dealer installed a 6in bds lift on my fx4 6.5 ft bed before i purchased it. Im assuming they did their research and it works fine with it... so far no problems with it, 4k miles
You and Wandell are exactly correct. I have spoke with several shops that feel the Rancho will not be a problem with the 2 piece drive shaft. If there is a vibration problem they suggested to drop the carrier bearing with a spacer or drop bracket. This is standard procedure with a F250 and up. Rancho has not tested this and will not say it will work. BDS, Skyjacker, and others offer the drop bracket for the F150 kit so it should not be too hard to get one or build one. Still doing some research but looks promising for the Rancho.
So you're saying that the BDS 6 inch lift has the the nessecary brackets and such for the two piece drive lines? The reason I'm asking is I'm about to pull the trigger on one and its going on a 2010 screw FX4 with the 6.5 bed.
Yes
