2007 -> 2010
2007 -> 2010 lift and tires?
I just bought a 2010 FX4 after having a 2007 FX4 with a 2.5" leveling kit, 3" blocks and 325/60/20's. The plan is to put the same setup on my 2010, it doesn't look like much has changed in that area so can I assume it will all fit the same?
I've ordered up a new AS 2.5" front kit, the rear looks like it will transfer over and the 20" wheel specs seem the same.
Any comments would be appreciated
I wouldn't say it's a biatch, I installed the 2.5" on my 2007 myself, with limited tools and basic mechanical knowledge. Yes, even a monkey could do it.
Trust him (and me)! I installed a 2.5" on my old 2004 and I helped a friend install a 2" on his 2010. The 2009 and up F150 has a stamped steel LCA, instead of the 2004-2008's aluminum LCA. The stamping has a ridge that makes it nearly impossible to even get the 2" in there without removing the entire LCA. The good news is that the rake is not as much on the 2009 and up, so a 2" makes it perfectly level.
Just wait until you install it! I have a 2.5" as well and it was a beyatch!
It's all done, I was limited with time so I had a shop do it so I don't know how much of a bitch it was.
One nice thing, with the 07 it rubbed pretty hard on the upper control arms at full lock, with the '10 it barely rubs at all. Now I've still got the 07 FX4 wheels on, the tire swap happens tomorrow.
I'll have some after the weekend, it's still got the 07 wheels on it now.
Well here it is. I absolutely love this truck, it gets major looks everywhere I go.
I have experienced the traction control suddenly cutting in when turning at speed, but hopefully that's just a result of the pcm confused by the increased tire size. My VMP tuner is in transit so I'll be able to confirm that next week.
While I think the 04-08 truck looks ideal with a 4-6" lift, the 09-10 definitely looks best with a leveling kit and slightly larger tires. Your truck looks great, perfect proportion. Love the FX4s, no ridiculous chrome overdose. I wouldn't change a thing. Well tint and exhaust, but thats personal preference.
