Rear Shocks
Old Jun 16, 2010 | 01:23 AM
muskoka_smurf's Avatar
Rear Shocks
40,000KM on 2009 and the rear shocks had to be replaced under waranty for leaking
I have also had the driveshaft and tranny done
now I have the loud click from the tailgate when you open on a hot day
driveshaft and tranny is common
anyone else have problems with shocks or tailgate noise
Old Jun 16, 2010 | 06:54 AM
sozzy1269's Avatar
Where is the click sound coming from in the tailgate? The hinge, handle? may need some lube.
Old Jun 16, 2010 | 07:48 PM
munro200's Avatar
what did you have done to tranny?
Old Jun 16, 2010 | 08:25 PM
Justi's Avatar
The tranny is one thing but the tailgate is an easy fix. White Lithium grease is your friend. Your owners manual on page 401 tells you to make sure to grease hinges, striker plates, etc..
Old Jun 22, 2010 | 11:05 AM
The click is a very loud twang (on a hot day) coming from the hinge when moving the tailgate up/down from 1/2 to 3/4 closed. Almost sounds like the end of a spring is broken. Anyone know if there is a spring assist for the tailgate?
Old Jun 22, 2010 | 11:23 AM
kingfish51's Avatar
Yes, there is a spring in the tailgate to make it easier to lift.
Old Jun 28, 2010 | 10:24 PM
Jimmylevesque's Avatar
Did the white grease help
I have the same problem with my Lincoln Mark Lt, did the white grease help?
