09 with bad front shocks
Old May 31, 2010 | 10:39 AM
r8rone's Avatar
My front tires are feathering...i only got 15,000 miles on the truck. I got the truck lifted with the 6" pro comp lift and 35" tires. Is it still under warranty? lift and tires were done at the dealer. If not i cant seem to find the front coil overs for our trucks. Pro comp makes them but only sell them in their lift kit (MX2.75C front coil overs). Thanks for the help
Old May 31, 2010 | 10:43 AM
kingfish51's Avatar
More likely need an alignment. As far as the shocks, the only one that ill warranty them is Pro Comp. They are not Ford products, so the will not warranty them.
Old May 31, 2010 | 10:50 AM
r8rone's Avatar
Its really bumpy when i go down the road, i had the dealer fix the alignment once already. Maybe i should rotate and balance the tires and see what happens. The coils also look like stock ones, so maybe they will fork over some new ones.
Old May 31, 2010 | 10:56 AM
Factory warranty is questionable after any kind of mod like that.
Old May 31, 2010 | 12:42 PM
sozzy1269's Avatar
If the dealer installed the lift, they should warranty it... and they can get reimbursed from Pro-comp... I've said it before and I'll say it again- Never buy Pro-comp products! They are cheap and sub-par. Case in point.
