Reverse lights... whats the best way?
Old May 26, 2010 | 12:30 PM
F_ast's Avatar
I have been reading up on Auxiliary reverse light installs and cant figure out if I want to wire direct to reverse light wiring so the light come on every time it goes into reverse, or the option to manually switch in only while in reverse or if I just wire a direct line to switch on whenever i choose.
I can see benefits and negative to each, but how would you do it?
And to the guys that already have done it, would you do it another way than you set yours up now that you have used it.
Old May 26, 2010 | 01:15 PM
tbraquet's Avatar
I wired mine with relays so they only came on when my heads lights are on. That way they only come on at night. Here my how to https://www.f150online.com/forums/20...ight-pics.html
Old May 26, 2010 | 01:44 PM
use a relay, on your 85 tap into the reverse wire, and also run a switched 12v into 85. put a diode inline with the reverse wire tap if you want to prevent your tail light reverse lights from coming on
Old May 26, 2010 | 04:09 PM
VTHokieF150's Avatar
I wired them up independently from the stock reverse lights on my '06. 95% of the time I'm in reverse I don't need them. But when I do, quick flip of the switch and there they are. Very nice addition for the times I do need them! If I were to do it again... I would keep them the same. Actually did do it again, had a set on my '97 set up the same way.
Old May 27, 2010 | 10:08 AM
BETCHER78's Avatar
The feed to the 7-pin ( if you have that ) would work out fine. Maybe run a couple wires into cab with switch , incase you want them off.
I would not want any situation where backfeed could occur, even with a diode there is still going to be a bit of voltage backfed. Our trucks will put up with a lot as long as you dont **** off the SJB.
I am probably going to tap into the reverse headed to the 7-pin. with a waterproof sw off of the mountin plate for the 7 and 4 pin connecotrs. to disable if i need too. i swapped out everything for LED. and that was an improvement, more noticable at night viewing backup camera. but more light is always good. i also have a 7pin light buster backup/aux light i use.
everyone have a great weekend.
Old May 27, 2010 | 12:33 PM
Frmboybuck's Avatar
If you use the proper diode, you will get zero back feed.
Old May 27, 2010 | 02:25 PM
F_ast's Avatar
I like this idea... you guys know if this is still accurate?
Opps... edit
The Red lead is the reverse light connection correct?
Old May 27, 2010 | 03:20 PM
redfx4150's Avatar
i think that above^ is right
when adding light and what not i like to run everthing on its own, that way if you ever have a issue the dealer can't say it was your fault, or let you down on the side on the road ( thats just my veiw)
but for reverse lights, if you tow its nice to have them on a switch. so that when you hooking or unhooking you can just leave the on, and i bet youll find other needs were youll just want them on to work behined your truck
Old May 27, 2010 | 03:37 PM
seadragon's Avatar
They also come in handy when someone behind you won't lower their high beams!
Old May 27, 2010 | 05:39 PM
F_ast's Avatar
Starting to think I am just going to hook it to the battery terminal with an inline fuse and have it on demand. Less fuss I suppose.
Old May 28, 2010 | 10:25 AM
L8 APEX's Avatar
I tapped the 7 way reverse wire on the F250. On the F150 I just threw one of those #20 Blazer reverse light deals in the 7 way and couldn't be happier.
Old Jun 1, 2010 | 12:51 PM
ridged43's Avatar
Opps... edit
I want to tie in a reverse sensing control module. Can you guys confirm the pin 6 (red) is the reverse signal wire and the pin 3 (white) wire is ground?
Thanks for any help.
Old Jun 1, 2010 | 04:08 PM
Papabare's Avatar
When I have wired in the 7 pin trailer light plug, Blue or 2 is to the reverse light circuit.
The European rear FOG lights are a light that comes on behind the red of the tail light housing (In our Jetta anyways) and uses the same bulb as the reverse lights.
