Differential lock in 2wd
Old Apr 26, 2010 | 02:17 PM
mayo7's Avatar
In the Raptor you can lock in your diffs in 2wd. Has anyone figured out how to do this in a FX4? Is it as simple as modifiying the pull out switch on the 4wd selector?
Old Apr 26, 2010 | 10:41 PM
L8 APEX's Avatar
With the wiring diagram you could run your own switch to engage the locker. There is a two wire connector on the driver side of the diff that engages the locker. Just a basic 12 volt switched input. I will eventually get around to doing this on mine as well.
