Pullsing to the right
Old Apr 2, 2010 | 11:28 PM
jcma81's Avatar
My truck is pulling to the right when I take my hand off the wheel. Is anyone else having this problem? I just had my tires rotated and I'm curious if this would have caused this. Also are there any issues with the Perreli tires and tire rotation? I have hear that some tires shouldn't be rotated?
Old Apr 2, 2010 | 11:51 PM
jetech00001's Avatar
well it could be a number of things did this problem start after the rotation ? have you checked the tire inflation is the tire on the right worn more than left front did the person doing the rotating cause any damage to your front end its better to do the maintenance your self this way you know its done right maybe you need a front end alignment
Old Apr 2, 2010 | 11:52 PM
Kauaikid's Avatar
If it started pulling immediately after having the tires rotated then that's likely the cause. The tires probably were wearing a little unevenly. How were they rotated? Generally, tires should be rotated front to back, keeping them on the same side of the vehicle.
Old Apr 3, 2010 | 01:25 AM
jcma81's Avatar
Im not sure how they did it i really hate this dealership
Old Apr 3, 2010 | 10:11 AM
ruff rider's Avatar
Speaking only for my 09 Lariat with 20 inch wheels. The front tires go to the opposite rear wheel and the rear wheels go straight up to the front. This is what the manual says.
