2010 platinum rear heated seats switch pin out
Old Feb 13, 2010 | 03:55 PM
racinwarrior's Avatar
hey guys i need someone with access to a 2010 wiring diagram to hook me up.....
i plan on installing rear heated seats in my 09 plat. i already have the 10 switch and plastic bezel.
i need to know the pin out for wiring purposes. also is there a separate control box for the seats or do you think i can run the switch to a latching relay and then to the seats.
please help and ill post pics of the install in the how to section
Old Feb 13, 2010 | 05:29 PM
nevermind i found it
for all interested
on the left switch:
1- high heat
2- switch illumination
3- +12 vdc for high indicator light
4- +12 vdc for low indicator light
5- low heat
6- ground
on the right switch:
1- low heat
3- +12 vdc for low indicator light
4- +12 vdc for high indicator light
5- high heat
6- ground
Old Feb 13, 2010 | 06:10 PM
ok guys rear heated seats from 2010 sucessfully installed in a 2009.
used 8 relays
4 diodes
4 heating elements
2 ford switches and bezels
total cost was $150
only difference is i dont have a hi/low feature. either position on the switch is just on. hi/low can be added with dual coil heating elements and 8 more relays and 4 more diodes
pm me for details
Old Feb 13, 2010 | 08:01 PM
Mickeymeanie's Avatar
Awesome idea... PM sent!
Old Feb 1, 2011 | 01:31 PM
r8rone's Avatar
Bumpin this back to the top! Can you give the part numbers and how you did it again? Thanks
Old Feb 3, 2011 | 10:22 AM
r8rone's Avatar
Anyone?
Old Feb 18, 2011 | 02:04 PM
SportTractoF150's Avatar
Racinwarrior hasn't been online since October, and Mickeymeanie (who said he would PM him for info) hasn't been online since July.
I sure would love to get some more details on this.
