My Keyless Keypad is dying
Old Jan 20, 2010 | 09:01 PM
volman's Avatar
Woke up Monday to find that the 7-8 button light had quit. Then this morning the 3-4 light is out. Anyone else had a problem with this? Went by the dealer and they had not seen it yet, THEY SAID.
Also had them look at the rear window rattle that I have (same one I had on my 04 FX4) and they said that was normal. But there was a TSB in 04 to fix this problem and they said I would have to wait for Ford to issue one before they could work on it.
I will also say the rattle/squeak you here in the window area right beside you on driver door is the plastic arm rest on the far left hand side. If you push hard on it the rattle stops. It looks like the plastic is rubbing up against the rubber seal there, I cut a small piece of black felt and put between the two and it is gone. I have the rear door/seat rattle too, I am going to check into some things that were posted on here. Love the truck, but I was hoping for a much improved truck from 04, it is so much better but still has the little things that drive you crazy!!
Old Jan 20, 2010 | 10:49 PM
OutlawFord's Avatar
Mine quit on me too, It worked prolly twice the last 50 tries. Id bring it to the dealer but I dont wanna go thru the hassle of them destroying my door panel lol
I thinking maybe a ground?
