Towing Mirror
Old Dec 29, 2009 | 10:59 AM
skidoos's Avatar
Towing Mirror
Can anyone tell me for sure or has done this swap can help . I have a 2009 f150 xlt super cab with regular mirrors no heat no turn and no marker lamps and would like to buy the ones from Tasca towing with Heat turn and marker lights . I know the heat wont work till I get a control with the switch but i was wondering about the turn and lights are they plug and play no one at the dealer can tell me for sure and it is darn cold out there to being pulling apart a door to check before I order . Thank skidoos
Old Dec 29, 2009 | 07:35 PM
skidoos's Avatar
Anyone
Old Dec 29, 2009 | 08:26 PM
kstrait's Avatar
Sorry...don't know either, but I'm real interested in what you find out.
Old Dec 30, 2009 | 08:47 AM
Dark_Wizard's Avatar
I don't know about the mirrors you are buying but the wires are in the trucks harness that you need to use. I am going to do the LED blinkers and will post the process including wiring schematics and part numbers for anyone wanting to do their own. It will be on the other forum...
Old Dec 30, 2009 | 08:37 PM
kstrait's Avatar
Definitely want to do that one, especially if it's low cost...what "other forum" do you mean?
Old Dec 30, 2009 | 11:53 PM
SoonerTruck's Avatar
Probably fordf150.net
Old Dec 31, 2009 | 06:22 AM
f150 forum . com
remove the spaces as it won't let me post it...
Old Jan 1, 2010 | 10:57 AM
N8-126's Avatar
I don't think it will work-without some work on your part. I just swapped out my FX4 towing mirrors for King Ranch mirrors. At least in my case the truck was only wired for the options that came on it i.e. no memory, no power fold, and missing a few ground wires. I am working now to find a female pin that will fit in the connector so I can wire up the grounds and power fold.
You can do the swap, but you will probably need to add some wires to the connector.
