Calling all Platinum owners....
All, I purchased the "Blendmount and Invisicord" to stealth mount my new Passport 9500x1 (great unit by the way). Anyway, there are no instructions specific to the '09 F-150 for the invisicord electrical connections. Anyone out there do this yet and would you please share with me which wire you used for the hot/switched lead and which is the ground lead?
The Invisicord comes with connectors that slide into the rear of the exising harness coupling - so no splicing necessary.
T.I.A.
I asked Platinum owners - so I would be sure the wiring would be identical as non-platinums may have different mirror options (and wiring) and the Plat also has the rain sensor wiring running behind the mirror.
T.I.A.
Nobody reply yet? What's the "Blendmount and Invisicord" ? Sounds like a good mod. I'd like to get a new Passport and have it hot wired to the ignition switch. I don't like the battery powered ones because I'd always forget to turn it on or off ;-)
I'm ordering an Invisicord and a Blendmout. Has anyone determined the correct pin connections on a 2010 Platinum with Nav?
Also, any suggestion on whether to get the Blendmount with or without hinge?
Mark - you have a PM...another member (Jim H.) sent me the correct wire connections and I have had my Passport 9500xi connected now for two weeks with no issue at all. Comes on/off with the key and works like a champ! The Bendmount/Iniviscord setup was fairly easy to install and really make the detector pretty stealth. I don't think I got the hinged model...and had thought that was only for certain rear view mirror types...check out their web sight - should steer you in the right direction.
http://www.invisicord.com/
I just swapped my V1 for the 9500ix - which if nothing else is a whole lot more pleasant to live with on a daily basis. Love the Redlight camera feature - as well as the speed display on the unit when it alerts.
no change needed to the invisicord BTW - straight swap.
Hey gh - it's a pretty slick mount for the radar detector right below the rear view mirror. Nice unit and makes a clean mount for your radar unit. The Invisicord plugs in the detector and into the rear of the mirror connector making it a very clean installation...no more power cord running down to the dash 12v outlet.
I haven't had a Passport hooked up since I got caught with one up in Va. several years ago. I find the speedometer a little difficult to read accurately on the '09 so it may be time to upgrade to the latest now. That mount is nice. Sure beats the old suction cups!
Thanks HotLap, Yeah, I finally started poking around and found their web sites today. Both of them sure are pretty proud of their products, huh?
...but they are quality and it is nice to have everything tucked away...good luck and let us know when you get it installed
