Yes, another Brake Controller Thread
If you have to post "do a search", put up the link
What is the difference between Part # 9L3Z-2C006-A and Part #AL3Z19 H32 AA? The 1st part number is what everybody posts they are putting in there truck for a brake controller. When I call Ford, they give me the 2nd number. I can get the one from my Ford dealer for $157.14, and my salesmen claims it will plug into the existing wire harness and mount in the little change holder thing (which I will never use).
Anyone have experience with both?
Thanks,
Greg
Thanks,
Greg
Just speculation here....
I have an '09, which I used the 9L3Z-2C006-A for -
I see you have a '10
There is a difference between the '09 & '10 brake controller, which is why the part numbers might be different?
The '09 controller has a screen that lights up and tells you your settings etc - the '10 has no screen (just blank front) and the settings show up in the dash cluster.
Maybe this helps?
Maybe this helps?
Then after they install it, and it doesn't work, and they don't know what to do next, you can give them the instructions.......
