newly installed back up camera not working
Old Nov 17, 2009 | 10:55 AM
BETCHER78's Avatar
If you do use sheilded wire ( which you should ) make sure you only tie 1 end to ground, where ever the 'best ground point' is found. Either in the back, or the front of the vehicle. Or you could make things worse, have current flowing on that sheild ( more than it can handle ) ect
Good luck!
bb
