Nitrogen in tires
Also, if the shop you use has a quality nitrogen generator, the fill will have very low moisture. Moisture is bad because it causes more expansion as the tire warms up (increasing the pressure more) and can also cause some rims to corrode faster.
Many gas station air pumps are full of water. Nitrogen fill greatly reduces the need to top off so the risk of intoducing water vapor is much less.
It's not snake oil, it's just that our trucks don't need nitrogen, best to just insure your supply of air is nice and dry.
It use nitrogen in my tires because it came free with my truck for the life of the tires. Yes, they tried to charge $299 for this service, but since they wanted to sell me a truck that day, they dropped the cost along with all the other BS tacked on.
Yes, to me the ride is better. I got a nail in my rear passenger tire and lost a good amount of nitro. No shop in my town had nitro to fill it back up when it was repaired, so they used good ol' air. The ride was horrendous with air in that one tire. I mean a night and day difference. It made the whole back end of the truck feel like a POS junker, it would hop all over the place when I hit bumps. It felt like the harsh 2-1 downshift, and while I have noticed THAT, it's never been that bad. So I took it back to the dealer I got it from and had them fill it up with nitro when I got my first oil change.
So call it a crock, BS, or snakeoil all you want. If it's free to me and I like the ride better, I'm using it. I've had the truck over a month now and after putting over 4k miles on it, constant funky Texas temperature shifts and with exception of that punctured tire, not once has the pressure in them dropped. When I put the gauge on them last week, they all read 35psi just as the day they were filled up.
Thanks, but I know the difference in how my truck felt before that, and how it feels now once it was corrected. The nitro free to me, so I don't know why anyone gives a sheet what I use.
I like the hydrogen idea! Just be careful on potholes or you might explode! LOL! I like helium...makes your truck float!
Seriously the main thing is to make sure the air you use is dry. If it full of moisture you will have a bad ride and it can mess up your wheels.
OK, I will chime in here. Seems like the change of pressure has already been covered so I won't beat that to death. I had the tires in my 09 Lariat inflated with nitrogen, as I had the tires on my Harley done when they were new. I did it because the ride is MUCH better. So, no matter what all the others say, I did it for the ride.
BTW, the Camry is a great car and so is the Fusion. Poor service when I went to look at the Fusion lead me to buy the Camry. Can't go wrong with either one if your looking for a midsize sedan and the new F150s kick a..
I am hard pressed to believe nitrogen makes a difference in ride quality. I have two dealerships that supply nitrogen and install into tires. I am going to call and see how much it is, if it isn't much, I will try and compare. Better calibrate my butt meter
Or, better yet, for the sake of testing, I will see if I spill any more beer with or without nitrogen
Nitrogen works well for vehicles that don't travel very many miles per year (motorhomes, trailers etc.). The oxygen in air attacks and breaks down rubber over time. these vehicles usually don't wear out the tread, they just come apart due to tread seperation. There are different grades of nitrogen, we use the highest grade (medical grade ) in our asphalt race tires because it has the lowest moisture content. If you're going to wear a set of tires out in two or three years it's probably not worth the money.......
the air you breathe is already 78% nitrogen, 21% oxygen and 1 percent other gas. The only issue is that the air tends to hold a lot of moisture (water vapor aka humidity), which can add up to 5% of the volume of the air. By going with pure nitrogen, you are eliminating most of that humidity and getting rid of the oxygen which tends to fluctuate more with temperature change.
Also, the rubber in your tires is semi-porous, which over time allows the smaller oxygen molecules to escape...nitrogen molecules are larger (albeit only about .3 times larger), so they keep your tires inflated to the proper pressure longer. Oxygen will permeate (basically seep through) through the rubber 3-4x faster than the nitrogen will. Really, you aren't seeing a huge benefit just because you are running pure nitrogen, you are seeing the largest benefit because you are getting rid of the humidity and oxygen inside of the tire.
Is it worth it? That is for you to decide. I run it because I have an endless supply of compressed nitrogen at work, and have a large bottle of it in my work truck...so it is just as easy for me to fill my tires with nitrogen as it is for me to drag my air compressor out.
The nitrogen thing came out of the aircraft industry. Commercial jets have long used nitrogen because it is free of water vapor and oxygen. This is a real problem when you go from seal level, 100*F, 70% RH to 35,000 ft, 0% RH, and -70*F. And the rims get pretty damn hot during landing, that's why the brakes are all carbon/carbon. The aluminum wheels would corrode like crazy without an inert gas. Could have used Argon just as well, but it costs more 3X as much.
It is better but only a little bit. I wouldn't drive out of my way for it or pay (much) extra money for nitrogen fill but it does hold a more constant pressure through temperature swings and it doesn't require "top-offs" as often. The helium and hydrogen in air can escape through rubber rather readily, the oxygen, not as fast, nitrogen lasts the longest.
How is it possible even in the smallest bit that the ride is better. Whether you have them filled with air, nitrogen or even helium the amount of psi you put in them is the same.
But you shouldn't run air in one tire and nitrogen in the rest because they have different rates of expansion so your tires will rarely all be at the same pressure no matter what the cold PSI is. You are not crazy, you were simply feeling the effects of running a different pressure in one of your tires.
