Should I get the rear blocks from AS
Im getting the 2" AS leveling kit for my 09. Was lookin at the ebay store and they have the 1.5 and 3" blocks for the back. Was wondering if I needed to look at getting them while I ordered the front. Will it sit dead level with the 2" be a little higher in the front? Will it look better with the lift in the back? plan on runnin 33x18 or 33x20s on it eventually.
I just ordered the 2.5" kit and the 3" block for the rear. I want the back a tad higher so when I pull a trailer it won't be sagging bad. I think front up 2.5 and rear up 1.5 is perfect!
I'm putting 20X9's and 305/55/20's.
I have the 2.5"/3" autospring lift on my truck, and I really like the stance. It is a little taller in the rear so it still looks like a truck. I had just the 2.5" for a while and it looked bad. Looked like I had a pallet of concrete in the bed.
The stock lift blocks measure 1.25" on the trucks with 4 leaves. I'm not sure if the 3 leaf trucks use the same block but I would guess so. So you will get 1.75" of lift with out back the rear kit. I used a floor jack under my receiver hitch to make sure I liked the stance before ordering the rear kit.
I would recommend just getting the front then decide if you want the rear.
Does your truck have 20" wheels or max tow? I think those trucks have the 4 leaf pack. Probably best to just look underneath, but I'm not sure it makes a difference.
I installed a AS 2.5 lift and it looks nice for the daily communte. As soon as I tow a boat and / or load my 6.5 bed, it certainly sags at the back big time in comparison to the front. I need to to adjust the headlights, it was so bad. Hence I am looking for lifting the back too, just to compensate when loaded.
