Looking For Stock Wheel Specs
Old Oct 22, 2009 | 01:24 AM
mayo7's Avatar
Does anyone know the offset for 18" factory wheels?
Old Oct 22, 2009 | 12:53 PM
wandell's Avatar
The OEM 17 and 18 inch wheels are 7.5 inches wide with 5.5 inches of backspacing.
Old Oct 23, 2009 | 12:35 AM
mayo7's Avatar
Thanks for the information. Do you happen to know the offset of the rim?
Old Oct 23, 2009 | 08:05 AM
BrainDonor's Avatar
from reading around this forum, I think they're +44
Old Oct 23, 2009 | 11:08 AM
cstanek's Avatar
Offset is the difference between the centerline of the wheel and the mounting surface of the wheel. Backspacing is the difference between the inside lip of the wheel and the mounting surface. So, if you know the width and the backspace, you can calculate the offset. Like wandell mentioned, the width of the stock 17s and 18s is 7.5 inches with 5.5 inches of backspacing. That means the offset is 1.75 inches [5.5 - (7.5/2)], or 44.45 mm. Because the mounting surface is toward the outside of the wheel, it is a positive offset. So, +44 (like BrainDonor mentioned).
Old Oct 25, 2009 | 12:51 PM
mayo7's Avatar
Thanks boys.
Old Oct 25, 2009 | 02:14 PM
bgrd351's Avatar
anybody know how much the stock rims weigh? Especially the 20" "chrome clad" rims. I'm trying to figure out if aftermarket ones would be lighter thus being worth the expense other than for looks.
Old Oct 25, 2009 | 07:11 PM
fishnfool's Avatar
How wide are the stock 20's on a 09???
