2.5" AS Leveling Kit Issues
Old Oct 10, 2009 | 07:30 PM
JCU Delt Ox's Avatar
Exclamation 2.5" AS Leveling Kit Issues
So I wasted the better part of my Saturday trying to figure out how to get my 2.5" AS Leveling Kit installed on my 09 FX4. Even with a spring compressor, there is not enough space to get the strut assembly seated. I can get the bottom in the bracket and then the top won't go, or I can get the top in position and the bottom won't go.
My question is for anyone that has actually installed a 2.5" AS kit in their 09+...did you get things to work, and if so, how? I've tried everything that I could think of and nothing seems to work.
Any help would be greatly appreciated as I've got a brand new truck on stands sitting in my driveway.
Old Oct 10, 2009 | 07:34 PM
ibcop's Avatar
Been there, done that. I know what you are feeling! The 2.5 inch kit is a bear to get re-installed. On my truck, the hub had to be removed in order for the assembly to go back into place. Just make sure you don't bind the brake line. It's a pain in the rump, but once you do one side, the other will be a breeze. Don't drive too long without getting the alignment adjusted.
Old Oct 10, 2009 | 07:40 PM
I guess i'm gonna have to teach myself how to remove the hub, good times.
Old Oct 10, 2009 | 07:50 PM
ibcop's Avatar
I know it sucks.....but it appears to be the issue with the 2.5 inch kits....it only needs a smidge more and it would go in.....I was damn near standing on the breaker bar trying to get that thing back in.
Take a break and then go back out....
Old Oct 10, 2009 | 08:11 PM
Hopefully it's a one-man job. Are there any how-to's floating around out there so I'm not feeling it out in the dark?
Old Oct 10, 2009 | 08:53 PM
Wes28376's Avatar
Here is a great write up. Hope it helps.
https://www.f150online.com/forums/su...t-install.html
Old Oct 11, 2009 | 09:36 AM
I had to call it quits. I spent a few more hours out there trying to shove things where they needed to go with no luck. I guess I'll have to take it to a shop and have them do it. It's always disappointing when you think you can handle something and it doesn't work out.
09+ Owner's Be Warned!! The 2.5" AS Leveling Kit is a Beast!!
Old Oct 11, 2009 | 10:16 AM
yetti96's Avatar
From my readings here a 2.5" kit will make the front end higher than the rear. Sounds as if the 2" kit makes it sit perfectly level. But different cab configurations can account for 1/4" to 1/2" easily in different stances up front.
Old Oct 11, 2009 | 11:26 AM
ibcop's Avatar
Right. Not every turck has the same stance so some will have better results with the 2.5 inch kits.
Old Oct 11, 2009 | 11:28 AM
ibcop's Avatar
I see you are from Ft. Bragg - you could go to the post auto craft shop and do it there? I know someone would be able to help you remove the hub. it looks like a real job to get off, but I swear it was like 25 minutes each side. Well, maybe the first side was a little longer than the other side.
No worries and when you are done, it'll be well worth it. And the kit will settle after a little while, so if you are sitting a little higher in the front, give it some time. Post some pics when you are done.
Old Oct 11, 2009 | 12:59 PM
Unfortunately, the Bragg Auto shop is no longer operating, so that's out. I'll have to see what the guys at the offroad shop want to charge for the install. I also have a readylift block kit for the rear to bring it up a notch. Unlike most, I don't really mind the rake of the truck and I'm just looking for a little more clearance all around.
Old Oct 11, 2009 | 02:02 PM
johnfields20's Avatar
ok JCU bolt the leveling kit to the spring. Put the bottom in....Then use a rachet strap to compress the spring assy. insterting it back in then taking another rachet strap to compress the uper and lower so you can get it bolted back together. I hope this can help.
ive found that a rachet strap will work better than the spring compressor just make sure that you use a decent strap.
Old Oct 12, 2009 | 07:20 PM
Well, I gave it one more go myself. Used the spring compressors while the front-end was still on the ground, to make it easier on myself. I popped both the upper and lower ball-joints as well. I even wedged myself into the fender well, put my entire weight down onto the lower A Arm, etc..., but still needed maybe another 1/4" for the lower part of the strut to slide into it's bracket.
So, I went to a local 4x4 shop just to see what they wanted for the install and they quoted me $400. To go from an $80 project to a $480 project was not going to happen. So, I have since decided to wait and go the full suspension lift route. One door closed is another door open.
Last edited by SSCULLY; Oct 13, 2009 at 10:17 AM. Reason: do not post items for sale in forums
Old Oct 12, 2009 | 07:27 PM
ibcop's Avatar
I'd say shop around....you can find someone to do it for about $100.....heck there may be some other forum members close to you. Don't give up on it!
Old Oct 12, 2009 | 10:17 PM
broncobran68's Avatar
I got mine in without removing the hub. I used a spring compressor, ratchet strap, and a pry bar. This was before autospring even knew there was a problem so I had no choice but to force it in. There are other feasible methods for installing it yourself. Do some searching, reading, and give it another shot.
