SCT SF3 on 2010 F150?
Old Oct 5, 2009 | 10:58 PM
mrpositraction's Avatar
Has anyone tuned there truck 2010 yet with this? I have mine from my 2007 F150 and told an update is all it would need. I am updating mine now (going on 2 hours and only 1/4 of the way done).
Just looking for results and experiences with the newer trucks.
Old Oct 6, 2009 | 05:51 AM
mishka's Avatar
I'm thinking of getting that tuner this week. Would be interested to hear if you get it updated and one of the pre-loaded tunes running and any feedback you got.
Old Oct 6, 2009 | 07:06 AM
Well, I let it update over night and it still isn't done. I had no idea it would take this long. It was over 3/4 of the way done when I left this morning for work. I will check it around 11 when I stop back home, maybe earlier if I am out and about. I will check the A/F with a stand alone wideband (after the cats of course, I am not putting a bung in my new truck quite yet).
Old Oct 6, 2009 | 09:02 AM
Wife just called, finally finished updating the software. Will re-download the tune revision and give it a try at lunch today.
Old Oct 13, 2009 | 09:13 PM
Did all the updates, no go. Contacted SCT, gave them all the codes and other jazz to hopefully get them to support it soon.
Old Oct 14, 2009 | 09:19 AM
Just heard back from SCT, supposed to call them today after 1pm (CST) and get the update I need to make this work on my truck. Also got confirmation that I can use E85 with the 91 octane tune which makes me very happy. The decreased cost and gas mileage is a wash on 87 octane, but to be able to run E85 which is much less expensive than 91 octane (93 octane here) and get the performance gains I am very excited. Plus with E85 and its much much higher octane rating than even 93, it is a safer fuel to run. Just not sure how these trucks act in the winter running E85. I have some experience turning other cars that were not originally meant to run E85 and they don't like temps below 50deg F. So we will see.
Old Oct 14, 2009 | 10:04 AM
used2vtec's Avatar
That is some great news right there!! Im glad to hear that SCT is working with you on trying to get everything working properly. I look forward to hearing your review.
Old Oct 15, 2009 | 04:05 AM
Tune is in! Only have ran 87 octane so far but you can tell a difference. The throttle response is much better and the shifts are nice for the most part, maybe a little firm under little to no load while just putting around. I had just filled up with 87 octane so I was unable to run the higher octane tunes. When this tank is empty I will fill up with E85 and put it on 93 octane (there is a 91 and 93 octane option) and crank the timing up as much as it will let me. Will report back.
Old Oct 15, 2009 | 10:57 AM
used2vtec's Avatar
Did you notice any pinging. There are a few people that have installed their tunes and noticed alot of detonation. I think they were running the Hypertech programmer though. I noticed you can change the timing, are you also allowed to go in and change the torque management shift points.
Old Oct 15, 2009 | 12:23 PM
I didn't notice anything, but with the knock sensors, they will catch knock way before I am able to here it. I will try and datalog sometime next week and see if I am able to log any parameters that tell me when the motor is pickinp up knock. The truck ran strong, so I don't think there was any major detonation, normally, a motor will fall on its face if this is the case. Once I get E85 in, detonation shouldn't be an issue.
