2009 non-nav, Sirius equipped owners!! Help!
Hey all..someone out there must have a truck with Sirius installed from the factory..I need your help.
I have a XLT with snyc, single disc CD with a SAT button, but alas, no Sirius.
I'd like to keep my eye out for the Sirius module..but I cannot find a part# ANYWHERE.
Can someone who has a similar set up to mine..but WITH Sirius have a look at their module and get the part# for me??
My truck was in for service..the rental they gave me was a Dodge with Sirius installed..wow, I forgot how much I miss my Sirius and was amazed how CLEAR it was (my old system was FM transmitter)
Appreciate it if someone can look around while their vacuuming..or what not.
Many thanks
Many thanks
Many thanks
Many thanks
My guess is it's behind the radio unit.
i did a little searching and came up with this. Take a look and see if this is what you are looking for.
http://oem-auto-accessory.com/visteo...ux_button.html
Don't know if it would work for sure, but I would think with the proper harness it should -
Ford OEM Sirius Tuner For Sale
Thanks JDTech..that one you posted should work for sure...I found a few sites like that, but never found that one!
Storm...Yeah I dont know. There alot of modules out there..but its hard to tell if they'll all plug in. I must have seen 8-10 different part #'s for Sirius modules out of 07 to 09 Fords..I would think as long as the plug on the back is the same..that it would work if you got the correct harness. Sirius is Sirius!
Thanks all..appreciate the help. I'll give Tasca a call to see if they can find a harness # for it.
2010 sirius radio
This is my first post so not sure if this is the proper way to ask a question....but.Are there any Ford part guys on here that could answer a question about what kind of parts are required to install sirius on a 2010 F150 that wasnt installed at the factory.Bought mine without and as part of the deal they were gonna have it installed.I thought it would look just like the ones on the lot that were factory installed but they sent mine out and screwed up my dash,aftermarket antenna mounted above 3rd brake light with clear silicone gooped around the light.Iwas PISSED,but they said they would make it right,I am an Infiniti master tech and have installed them before,just mount the control unit and antenna,plug and play.Now they tell me they have to order me a new radio thats sirius compatible? they installed something but said it wouldnt work I would need a new radio.Any help would be appreciated,I just dont want them to screw my truck up.
