6 Speed tranny?
Old Aug 23, 2009 | 02:32 PM
munro200's Avatar
6 Speed tranny?
Ok so the tranny in the 5.4 is a 6 speed but when you look at the floor shifter on the console it only shows D,3,2 and 1 so are the other 2 gears on the top end or the bottom? Or how does this 6 speed work?
Old Aug 23, 2009 | 03:16 PM
F150Aggie's Avatar
They are on the top end, but the time you get to the higher gears you might as well be in D anyway.
Old Aug 23, 2009 | 04:37 PM
Tbird69's Avatar
It basically works the same as the old 4 speed. The difference being is you have one more cruising gear (4th) and two overdrive gears (5 & 6) at the top end.
Old Aug 24, 2009 | 01:17 PM
newmandl's Avatar
Does anyone have the gear ratios for each of the 6 speeds?
Old Aug 24, 2009 | 01:50 PM
APT's Avatar
APT
1st - 4.17
2nd - 2.34
3rd - 1.52
4th - 1.14
5th - 0.86
6th - 0.69
Rev - 3.40
Old Aug 24, 2009 | 01:55 PM
newmandl's Avatar
Interesting, so there is no actual 1:1 anymore. I did not know that.
Old Aug 24, 2009 | 01:57 PM
APT's Avatar
APT
Yep, and there is no particular reason for it any more, especially for automatic transmissions.
