higher octane
Old Aug 23, 2009 | 08:32 AM
ronfx4's Avatar
higher octane
Waht disadvantage would higher octane over 87 play in our trucks with the 5.4? Reason I'm asking, I've been running 87 shell, but started noticing better performance using 93 octane shell.
Old Aug 23, 2009 | 10:33 AM
BIG_ole_TRUCK's Avatar
The disadvantage you'll feel is in the wallet. Spending extra money for no gain.
Old Aug 23, 2009 | 10:38 AM
The truck is tuned for 87. That is what it needs. You will only waste money and possibly add internal deposits running anything higher. If you want more performane, get tunes that take advantage of higher octane.
Old Aug 23, 2009 | 10:44 AM
Veteran: Army
if you're tuned for it you can get better mileage and save money by running the higher octane
or if you are boosted then you need the higher octane
Old Aug 23, 2009 | 11:54 AM
ronfx4's Avatar
I'm having a level 10 programmer installed. How will this and the higher octanne produce better performance and economy?
Old Aug 23, 2009 | 12:00 PM
I know nothing about that one. Haven't heard of it. Most of us use the Edge, Xcal3 or the Gryphon.
Old Aug 23, 2009 | 12:14 PM
Veteran: Army
I bet the level 10 is a silly gimmick since nothing was located when I googled on it
Old Aug 23, 2009 | 01:27 PM
ronfx4's Avatar
I went in yesterday to levelten. They took reading of my vehicle's computer driving it, and said they would create a program for it. This is there website. http://www.levelten.com/
Old Aug 23, 2009 | 02:04 PM
Tbird69's Avatar
The compression ratio of the 3v 5.4 allows for the use of anything from 87 to 93 octane without any ill effects outside of the increased cost. 93 burns more smoothly and completely which is why you noticed better performance with it. This doesn't mean increased MPG, the extra cost of 93 will more then offset any gain you see in MPG.
Old Aug 23, 2009 | 02:14 PM
ronfx4's Avatar
I would think that the better performance is more than worth it and it may be enough not to bother with a programmer. Burning smoother would also have better long term benefits with emissions, and motor longevity.
Old Aug 23, 2009 | 02:19 PM
No, that is incorrect. You are not listening to what everyone is telling you. There are no gains if it is tuned for 87. If you won't take our word for it, go on a tuner site and ask your question. www.powerhungryperformance.com
Old Aug 23, 2009 | 02:33 PM
ronfx4's Avatar
The specs on this motor state E85 390lbs torque, and 87 gas 365 torque. We all know that E85 is well over 100 octane. So what am I missing here?
Old Aug 23, 2009 | 03:01 PM
v_tach's Avatar
93 burns more smoothly and completely...
...and the persistent myths about octane continue.
Old Aug 23, 2009 | 03:15 PM
Tbird69's Avatar
Then enlighten us, O wise one.
Old Aug 23, 2009 | 04:00 PM
You are missing the fact that that engine is tuned for E85. That is a whole different ballgame. If your truck is tuned for 87, that is what it expects to burn. Anything else will be a waste. These are computer programs you are dealing with. Is your engine an E85? Youhad not said that previously.
