seems like dashlights only work with daylight sensor ?
There are times when it is overcast outside in the morning/evening and I turn the headlights on (manually) but the dash lights don't come light up. Is this because they are connected to the daylight sensor? My 06 dash lit up whenever I turned the headlights on.
They are connected to the light sensor and only come on when its dark enough. It was wierd when I first bought the truck, i had it to the dealer thought it was a wire issue but turned out to be the way they operate with the sensor.Took a little getting use to
Thanks..............
