After Market Brake Controller Installation
Old Aug 1, 2009 | 04:37 PM
jasontjames's Avatar
I have an 09 Lariat Screw that did not come with the integrated brake controller. I would like to put the prodigy that I had in my '03 in it. The problem is that they attached the pig tail to the back of that slot. The instructions indicate that I will have to basically disassemble the entire flow through console. Does anyone know a simpler way to accomplish this task?
Ultimately I would like to mount the after market where the factory one would have been. It fits perfectly in that slot, but I need to know how to get that piece of molding off. Preferably without disassembling the entire truck. Thanks for any insight you might lend.
Old Aug 1, 2009 | 06:05 PM
I figured it out.
I removed the bottom piece of molding by the gas pedal and reached up to disconnect the pig tail from the cubby hole. I then drilled a hole in the back of the cubby to run my wires through. Wired it up, slid the controller into the cubby and called it good.
Old Aug 1, 2009 | 09:20 PM
stormtech's Avatar
Glad you figured it out -
Was waiting for another member here to post who did the same exact thing - has pics and all.
Old Oct 2, 2009 | 09:29 AM
Ctrl@ltDel's Avatar
Can someone post pics of this for a noob?
Edit: Never mind....found it!
https://www.f150online.com/forums/20...tallation.html
Old Oct 2, 2009 | 09:54 PM
d4studmuf1n's Avatar
the flow through console is really easy to take out, you can have it out and back in, in under 30 mins, its like 6 bolts 3 screws and some push clips
