Steering issue or not?
Old Aug 1, 2009 | 12:30 PM
roberto232's Avatar
I’m not sure if I’m having a steering issue or not. While driving no problem, but when I’m stopped and I turn the wheel it’s really hard to turn. My question is if I’m having a steering issue or if the tire size and heavier weight of my Supercrew is the reason? Anyone else having problems like this?
Thanks for any input.
Old Aug 1, 2009 | 02:16 PM
K-9 SAR's Avatar
Mine is easy to turn when stopped and the motor running.
You could see if it feels the same as when the motor is off... if it does, your power steering pump is bad.
Old Aug 1, 2009 | 03:15 PM
jetech00001's Avatar
yes it will be a little harder to turn when wheel is stopped it has more resistance than a turning wheel how does it feel when driving and any doubts i would stop by your dealer and try one out with same size tires and wheels i sure you will find its ok.
Old Aug 1, 2009 | 03:58 PM
roberto232's Avatar
When I'm driving no issues.....even if truck is just moving slow.....it's just at a dead stop
Old Aug 1, 2009 | 07:16 PM
ROBERTO232 i have the 275/55r/20 tires and rims that came with my supercrew i went out and tried turning the steering wheel and truck not moving and yes it takes more pressure to turn the steering I.M.O. you don't have a problem like i said before drive down to the ford dealer and try another truck good luck
Old Aug 3, 2009 | 10:26 PM
roberto232's Avatar
Old Aug 3, 2009 | 10:31 PM
BIG_ole_TRUCK's Avatar
Bring it to the dealer to check out. Some members had similar problems; Ford replaced the power steering pump.
