Looking for partial wiring diagram
Old Jul 18, 2009 | 02:00 PM
stormtech's Avatar
I'm looking for a wiring diagram just for the front parking lights/turn signals.
Should be just 3 wires - park, turn, and ground.
Need to know what color wire is what.
Old Jul 20, 2009 | 08:25 PM
HotLap's Avatar
Storm - wish I could help ya, but I too would like to know the schematic for the '09's
Old Jul 20, 2009 | 08:50 PM
Justin_w32's Avatar
Do the Chilton or Haynes manuals have them I think I saw some wire diagrams in mine I have an 05 though. Might be hard to find one for an 09 being that they are so new.
Old Jul 20, 2009 | 09:13 PM
stormtech's Avatar
Yeah, I know it's hard being an '09 - was hoping maybe a Ford Tech might be able to help out.
It won't be too hard to identify the wires with a tester, but I always like to study the proper wiring diagram before I start anything.
Old Jul 20, 2009 | 09:33 PM
ibcop's Avatar
Good advice. I am still trying to determine the correct color codes for the lock/unlock wires in the 09's.
Old Jul 20, 2009 | 09:51 PM
Greg_B's Avatar
I don't know how to post a diagram (pdf format), but here's the info you need:
Left Front:
pin 1 = ground wire BK-GY (black/grey)
pin 2 = park lamp wire VT-WH (violet/white)
pin 3 = turn signal wire BU-GN (blue/green)
Right Front:
pin 1 = ground wire BK-GN (black/green)
pin 2 = park lamp wire VT-WH (voilet/white)
pin 2 = turn signal wire YE-VT (yellow/violet)
Greg
Old Jul 20, 2009 | 10:47 PM
stormtech's Avatar
Greg - you are 'da man!!
Thanks so much!
Would it be possible for you to email me the diagram?
stormtech at gmail dot com
If not, that is fine - I can make do just fine with what you posted.
Old Jul 21, 2009 | 07:48 AM
ibcop's Avatar
Greg- wouldn't have the power door lock wire colors would you? I'd like to tap into the wires on the drivers side rear door for the tail gate lock.
Thanks!
Old Jul 21, 2009 | 08:35 AM
Greg_B's Avatar
Thanks so much!
Email sent...
Greg
Old Jul 21, 2009 | 08:38 AM
Greg_B's Avatar
Thanks!
I can check for you later tonight...I'm at work now and don't have the service manual CD with me here.
Also, it might be easier to send me your email address and I'll send you a PDF file of the wiring diagram. Either way is fine.
Greg
Old Jul 21, 2009 | 09:07 AM
stormtech's Avatar
Originally Posted by Greg_B
Email sent...
Greg
And received - thank you Greg - this is a big help.
Old Jul 21, 2009 | 09:19 AM
v_tach's Avatar
Maybe some of you will find this helpful. Its the Ford technician documentation for a variety of 2009 models (including the F150) for installing the Ford security systems. There are wiring charts for each model.
http://www.unlimitedhardware.com/F15...rm_install.pdf
Old Jul 21, 2009 | 05:05 PM
Greg_B's Avatar
Thanks!
For the rear doors (both sides), the two wires going to the door lock actuator are as follows:
VT/GY (violet/gray) - goes hot for unlock, ground otherwise
GY/BN (gray/brown) - goes hot for lock, ground otherwise
The function of the wires for lock/unlock seems to be as I have stated above (my interpretation of the diagram), but it's not explictly stated in the diagram, so the operation may actually be reversed (switch unlock and lock above).
Hope this helps...
Greg
Old Jul 21, 2009 | 07:33 PM
ibcop's Avatar
Greg
Thanks - I sent you a PM with my email address.
Old Jul 21, 2009 | 07:37 PM
ibcop's Avatar
Great to have. Thanks for the link.
