Strange problem with engine noise
Ok when i start my truck and let it run for 20-30 secs it starts to get a high pitch whine. It aint really loud but it's very high pitched. When i increase rpm's to 750+ it goes away and then when it returns it comes back again. Anyone have any idea what this may be?
I used to have a 99 ford some time back and had the same issue. I thought it was the alternator but it was actually one of my idler pulleys. I was able to track it down with some spray lube as I went from pulley to pulley until I found the one causing the noise.
Hopefully it is nothing more than that or the alternator.
On my '08 w/5.4, I had a 'woot' or 'whistle' at idle when cold - this actually only happened below 35deg F.
There was a TSB for it - for an idler pulley replacement.
Doubt if your is the same issue being it's not cold now unless you are in the southern hemisphere.
I just been out ther eagain and messed around with it and it's 85f outside and it dont do it as soon as i start it but it starts a few secs after. It's very high pitched like one of them cat scare gadgets.
Then maybe listen closer to your A/C compressor - I know I can hear mine "grunt" for a second or two a few seconds after I start up.
Maybe try turning the climate control completely off while the truck is running, then kill the motor, and start it again - if it doesn't do it then I would think it is your A/C compressor.
I have turned the AC of whilst it's makeng the noise and noise still stays on. It dont sound like it's coming from the alternator but it's so hard to tell with how high pitched the sound is. I will try and get a closer listen the ac compressor
did you try some lubricant on the pulleys? or a belt dressing with any results?
