Line of fire
Line of fire
Has anyone installed one yet? im looking to put one on, was wondering whats all has to be done, if there are one for 09 f150, or all universal. Also where to get?
I've got one on mine and I like it. Just order the 60" version and you should be fine. I have a Recon brand and like it pretty well. Some sites say it won't fit with the tailgate step, but I have the step and I was able to make it work. There is a bracket on my 09 that sticks out on the right side and get's in the way a bit, but you can move the one bracket and make it fit.
The install can be pretty wasy as it comes with a 4 way plug and will plug into the 4 way trailer plug. I chose to wire mine into the back side of the plugs. When you install them, it's easier if you remove the tailgate after locating it. You also need to be cautious about anything getting in between the tailgate and the light bar when the tailgate is down. A rock will do a number on the light bar when you close the tailgate if you aren't careful.
I plan to tint the tail lights on my truck some and figure the line of fire is a good addition to the truck for additional lighting when needed.
Here is a picture of mine.
Make sure it doesn't flash or give off too much flare. It could be perceived as a police officer and impersonating a law enforcement office is a major crime. I say leave the flashing light to Michael Knight and KITT
All RECON products are SAE & DOT approved for street use.
